copper line fault???
- copper line fault???
06-09-2011 4:45 PM
Hi to anyone who can help! I am not sure if I am posting to the right forum area but any help would be much appriceated.
I recently moved house and contacted my ISP to let them know we would like our internet service moved to our new home....nice and easy said the nice man on the phone! That was over four weeks ago and still no internet!
After many phone calls to them and several tests been carried out this was the last message i have from them.
Fault results;-
RADIUS;-
No RADIUS results within last 7 days
NIC;-
Clear
xDSL;-
Sync Status: Circuit In Sync
General Information
NTE Status: In Service NTE Power Status: NTE Power On Bypass Status: Bypass Not Activated
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 19 40
SNR Margin: 24 0
Errored Seconds: 6 1
HEC Errors: 9 0
Cell Count: 11648 5000
Speed: 448 8032
Maximum Stable Rate (KBPS): 7968 Fault Threshold Rate (KBPS): 6374
Mean Time Between Retrains (Seconds): 133 Mean Time Between Errors Upstream (Seconds): 49
Indicative Line Quality: R Mean Time Between Errors Downstream (Seconds): 394
CLT;-
PSTN Fault Report
Telephone number ****************
Status Date reported Date completed
Open 01 Sep 2011 Not completed yet
TAM;-
Analyst;-
Open CLT fault unable to proceed / possible Auth
Upstream/Downstream <430 at 49/394 with 6/1 Errors seconds. With ILQ R
This means absolutley nothing to me, they have advised me to contact BT.....what for I don't know....how to fix this....I don't know that either.....all I want is my internet to work.
please help.
Kind regards,
Paul.
Fault results;-
RADIUS;-
NIC;-
Clear
xDSL;-
General Information
Loop Loss: 19 40
SNR Margin: 24 0
HEC Errors: 9 0
Speed: 448 8032
CLT;-
PSTN Fault Report
TAM;-
Analyst;-
please help.
Kind regards,
Paul.
Message 1 of 9
(7,575 Views)
8 REPLIES 8
Re: copper line fault???
06-09-2011 4:50 PM
The above information is mainly line stats but it also seems to indicate that a line fault may be present.
I'm sorry things have taken a while so far with this. I'll look into this further and come back to you, fingers crossed I can help things move along a little more quickly now.
Adam.
Adam.
Message 2 of 9
(1,767 Views)
06-09-2011 4:52 PM
Right, I can see the issue after having a quick look at the account. It's the terminology we've used: PSTN provider means the same as your phone provider, i.e the company you pay your phone bill too.
We've identified from tests an issue with the line itself so I'd advise contacting them.
Any more questions do let me know though.
Message 3 of 9
(1,767 Views)
06-09-2011 4:57 PM
Hi Adam, thank you very much for your speedy response to my query.....I have contacted BT and they say that my ISP should be sorting this out.
if this is correct please can this be sorted..or who can I contact at Plusnet to get this moving forward.
Once again thank you for your help so far.
paul
paul
Message 4 of 9
(1,767 Views)
06-09-2011 5:05 PM
Sorry about this to be certain I've performed the same test again and there is still a copper line fault showing which we're unable to help with.
This probably won't be what you want to hear but you'll need to call them back again and advise that we have run a "copper line test" which fails repeatedly and that indicates a line fault.
Any more issues give me a shout.
Message 5 of 9
(1,767 Views)
06-09-2011 5:07 PM
Okydoky,
back to BT I go.....speak soon
paul.
paul.
Message 6 of 9
(1,767 Views)
06-09-2011 5:16 PM
Message 7 of 9
(1,767 Views)
07-09-2011 4:07 PM
Hi Adam,
Hi, As per your request and phone call, I called BT, they still say there isn't a fault and repeatedly mentioned the cost involved to me should an engineer be called and it's my equipment that is faulty!
I have purchased a new router, enetred the same details as my old one (log ins and passwords) etc. this one everything goes green (DSL line, WLAN) apart from the connected to the internet image...this stays red.
The progress screen on my computer that shows me the progress of the internet connection keeps saying that it is synchronised (goes green) then the next time it refreshes it is not synchronised (red cross).
ultimatly the internet never goes green always stays a red cross.
does this information help to cure my lack of internet?
Paul.
Paul.
Message 8 of 9
(1,767 Views)
07-09-2011 5:10 PM
Quote Hi, As per your request and phone call, I called BT, they still say there isn't a fault and repeatedly mentioned the cost involved to me should an engineer be called and it's my equipment that is faulty!
Shame, I feel sorry for you getting messed around here, I'm going to do some tests from this end to see (amongst other things) if the copper line tests are still failing.
Quote does this information help to cure my lack of internet?
it certainly does thanks, plus trying a different router does rule that out as being the cause of the issue.
Given the time of day there's not a great deal I can do right now but I will give this some attention tomorrow morning so I'll give you another call if you like.
Adam
Message 9 of 9
(1,767 Views)
