continued service with fibre only?
jethro247
If i switch to fibre only (no landline) will there be a break in service during the switch?
is there any installation/change required, or will it just carry on as usual with no disruption?
many thanks
2 REPLIES 2
Legend
Fixes: 289
Re: continued service with fibre only?
@jethro247 There should be no break in service that you would notice - these changes are 'flick a switch' tyes of changes, although if you were online in the small hours, you may experience a short break.
There is no 'installation' required.
jethro247
thank you!
