contact Plusnet about slow broadband
Jtate1
My Broadband is 1.43mbs and I believe should be 6-9.
Text fault reporting fails every time.
I have problems speaking and hearing by phone.
I can't find chat or an email contact.
I don't use Twitter (and I don't think social media should be used for commercial matters)
Please, how can I contact Plusnet?
In the meantime I'm using my pitiful broadband to check out other providers. My Plusnet has been faultless for years but now there's a problem I can't even contact them
17 REPLIES 17
Fixes: 334
Re: contact Plusnet about slow broadband
@Jtate1 Welcome to the forums. Unfortunately, there is no text/email support for these issues, but you have found an avenue which should hopefully assist you.
From the figures you quote, I am assuming you are on an ADSL connection? From what you have said, you do have a problem - unfortunately the bots do not always pick these up, and it falls to a process of elimination via these forums.
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Fixes: 457
Moderator's note: Thread moved from Plusnet Feedback to Broadband
Fixes: 87
@Jtate1
In addition to what's already been said you can register with PN for additional support due to your speaking / hearing problems.
I don't have the link to hand but if you look through the Help pages you should find it.
Fixes: 457
@Jtate1
First of all is your telephone working? If not thenyou need to report a phone fault to however provides your phone service. If Plusnet or if you do not have a phone then why doesn't the mobile phone text service, See https://www.plus.net/help/report-a-problem/ work if you report a broadband problem
An older slower method of reporting a fault, which I believe still works is:  https://faults.plus.net/.
If you try to change service whilst you have a network fault will result in it taking even longer to fix as you will simply take it with you and have to start again.
Fixes: 123
@Jtate1
This is the link being mentioned
https://www.plus.net/help/legal/accessibility/
Fixes: 334
Just beat me to it, @Dan_the_Van .
Fixes: 334
@Baldrick1 wrote:
@Jtate1
All covered (I think) in my original post. The old 'faults.plus.net' link still works, but is excruciatingly slow to get a response on.
Good point re: changing providers with a current fault, though.
Fixes: 235
If the broadband fault checker is failing ... try using the phone fault checker.  You need a good working phone line for broadband to function properly.
Jtate1
Many thanks. The links were helpful up to a point.
I've established that it's a line problem (the phone is very crackly.) I plugged a corded phone into the master socket and it was still crackly, just as before. So I went for the 'report a fault' option, but that lead me to the text option which doesn't work. The alternative is a phone number and I have problems with that, especially over a noisy line.
So I still can't report the problem, unless it can be reported through this forum.
Many thanks to everyone who's kindly made suggestions here! I'm some way nearer a solution...
John.
Fixes: 457
1. What do you mean by the text option ‘doesn’t work? Are you fully following the instructions?
2, Did you try https://faults.plus.net/?
Fixes: 334
@Jtate1 You say the text option doesn't work - in what respect? As I'm no longer a PN customer, I  can't test it, but as I understand it, you follow the guide below, which merely involves texting 'PHONE' to the supplied number.
Jtate1
The text option doesn't work! I sent three texts to 07800008121 and all of them failed.
As to the faults.plusnet link, many thanks. It helped me to establish that the oroblem is in the line - but when it came to reporting the fault there's only the text option, which didn't work, and the phone number, which I have problems with, especially on a noisy line.
Many thanks to you and other contributors for all your excellent help. I'm very grateful - but apart from writing it here I still haven't been able to communicate the fault to Plusnet.
John.
Fixes: 334
As I'm curious - in which way did they 'fail'?
Fixes: 334
@willcutforth - can you assist?
