connections drops after switch to plusnet
cieju1
I've just switched to plusnet from o2/sky. I use my own router dlink 2740b and connection drops constantly no matter where router is connected extension or master socket so I went through all your guides on website and I found that connection is quite stable if router is plug in to test socket. I had stable connection in 18 hr time. Looks like something is wrong with my home wiring  but it is a little bit odd  to me cause last week all was ok I had very stable connection from o2 for 3 years and now after switch magically my router  is unable to connect to exchange.Im still in 10 days switch over period but I dont think I have problems because of that. Speed is also disappointing I had 12 Mb now I have only 3 Mb.
Below i give you my router stats which is connect to test socket thorough Ethernet cable.
WAN STATISTICS
Service VPI/VCI Protocol Interface Received Transmitted
        Bytes Pkts Errs Drops Bytes Pkts Errs Drops
PPPoA_0_38_1 0/38 PPPoA ppp_0_0_38_1 4746263 3965 0 0 806724 2568 0 0
LAN STATISTICS
Ethernet 1117620 4146 0 0 5400461 4718 0 0
Wireless 18800 49 0 0 12078 74 100 0
ADSL STATISTICS
Mode : ADSL2+
Line Coding : Trellis On
Status : Link Up
Downstream Upstream
Rate (Kbps) : 3068 446
SNR Margin (dB) : 23.8 28.6
Attenuation (dB) : 35.0 20.9
Output Power (dBm) : 0.0 12.8
MSGc (number of bytes in overhead channel message) : 63 46
B (number of bytes in Mux Data Frame) : 14 19
M (number of Mux Data Frames in FEC Data Frame) : 1 2
T (Mux Data Frames over sync bytes) : 6 1
R (number of check bytes in FEC Data Frame) : 16 10
S (ratio of FEC over PMD Data Frame length) : 0.1547 2.7211
L (number of bits in PMD Data Frame) : 1603 147
D (interleaver depth) : 160 8
Delay (msec) : 6 5
Super Frames : 7328 6886
Super Frame Errors : 0 0
RS Words : 3033916 172092
RS Correctable Errors : 0 0
RS Uncorrectable Errors : 0 N/A
HEC Errors : 0 0
OCD Errors : 0 0
LCD Errors : 0 0
Total Cells : 854173 123384
Data Cells : 102083  19288
Bit Errors : 0 0
Total ES : 0 0
Total SES : 0 0
Total UAS : 32 31
Fixes: 57
Re: connections drops after switch to plusnet
It's likely that you have the 'ring' wire connected ( see here http://www.kitz.co.uk/adsl/socket.htm ). This introduces noise onto the ADSL signal and needs to be removed.
Not really, the BT Wholesale system has something called Dynamic Line Management(DLM) which attempts to stabilise the line and reduce errors by increasing the Noise margin and thus reducing the ADSL speed. The sky/O2 LLU system does not have this and just lets the errors occur. In your case it looks like the problem is so severe that the line has been 'banded', where the speed is limited to a defined maximum.
Check if the 'ring' wire is connected and if so, remove it. Then post back here and hopefully one of the PlusNet Digital Care(DCT) team will spot this tomorrow and see if it's sensible to get the 'banding' lifted
cieju1
Thanks for quick answer just checked master socket and I have no ring wire connected.
Fixes: 57
Oh dear! I was fairly sure it was a simple ring wire problem. We would normally suggest posting router stats from the both test socket and the normal socket to confirm whether it is definitely an internal wiring issue but your line is banded then that's not going to show the problem. I would suggest raising a fault but since you're still in the 10 day training it might be worth seeing what the DCT team recommend tomorrow.
Kremmen
When I first switched to PN I had exactly the same problem.
I can only guess that LLU connections don't care about dodgy lines. I even used to turn my router off overnight and when the PC wasn't in use and then back on when needed with no issues.
BT 21CN does need a good stable line or you will suffer continually dropping speeds via the DLM regime. I was losing about 300kbps daily as a result. The staff here were manually increasing this periodically, when asked, to compensate.
In my case I reported a fault and PN duly followed it up. One Saturday afternoon my phone went dead for about an hour followed by the BB. Once they came back up I have been continually DSL connected without issue since.
= it's a matter of reporting then waiting.
Let's be careful out there !
Fixes: 75
I've just looked into this for you @cieju1 and I can't see anything obvious, however I'm wondering are you still connected to the test socket? If not something has obviously improved so I'd just keep an eye on things over the next couple of days (I can generate more connection graphs if needed) otherwise if it is still in the test socket I'd definitely advise raising a fault as the next step: http://faults.plus.net
<img src="http://community.plus.net/visualradius/generated/image13734540777289.png"/>
 Adam Walker
cieju1
Im still using test socket so as you guys advised Im raising a fault ticket right now.
cieju1
My 10 days test period is over I can see improvement my connection is more stable after turning on interleaving but speed is disappointing  I get only 1148Kbps. I tested both extension and test socket and Im getting similar results:
Download speedachieved during the test was - 0.96 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-1 Mbps.
IP Profile for your line is - 1.01 Mbps
Upload speed achieved during the test was - 0.36Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
router stats from dmt  extension socket
test socket
in the meantime I received message from PN support  that further investigation is required and I need arrange visit but 60 quid charge put me off. Im quite sure its not my fault as with my last provider everything worked perfectly just two weeks ago.
What do you guys advise me?
Fixes: 62
Raise a fault - it won't get fixed otherwise
Basically because of the instability your line has been banded
Our faults team have updated your ticket requesting to send an engineer, we just need to know some availability from yourself for this.
cieju1
After engineer visit connection is quite stable and modem sync speed is 12942 kbit/s.
This is what im getting now:
despite of that my brodband speed  is only about 400kbit/s.
Why Im getting so slow internet connection?
houlton23
What does the 'Current Line Speed' say from here?
cieju1
Telephone number:
01793*******
Phone exchange:
STRATTON ST MARGARET
Estimated line speed:
6Mb (This may vary between 4Mb and 8Mb)  - Checked on 2013-06-28 17:50:45
Current line speed:
0.4 Mb
houlton23
Quote from: cieju1
Current line speed:
0.4 Mb
There's your problem!
The staff who monitor the forum have likely gone home by now so I'd suggest you give PN a call and ask them to fix your profile (say it doesn't match the BT one).
Hi, just bumped your profile on our side up to 10000 to match that set on BTs, hope things improve? They should do shortly, please let us know if not.
