connection up & down
- Re: connection up & down
18-04-2014 5:45 PM
I've noticed in the last hour or so my connection won't stay up for more than a few minutes, can anyone see a clue to why in the logs below from my Billion 7800N? I've obscured by static ip, my usual download speed is 8-10,000.
Apr 18 16:54:08 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:54:08 user syslog: begin: interface: ppp_0_0_38_1 go to down
Apr 18 16:54:08 user syslog: end: interface: ppp_0_0_38_1 go to down
Apr 18 16:54:14 daemon pppd[617]: Connection terminated.
Apr 18 16:54:14 daemon pppd[617]: Connect time 4.2 minutes.
Apr 18 16:54:14 daemon pppd[617]: Sent 94859 bytes, received 126608 bytes.
Apr 18 16:54:14 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=4
Apr 18 16:54:14 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Apr 18 16:54:14 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Apr 18 16:54:14 user kernel: after reset to 0, dev->refcnt=0
Apr 18 16:54:17 daemon pppd[617]: PPP: Start to connect ...
Apr 18 16:54:19 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 16:54:19 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 16:54:19 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:54:22 daemon pppd[617]: PPP LCP UP.
Apr 18 16:54:51 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:54:54 daemon pppd[617]: PPP LCP UP.
Apr 18 16:54:58 daemon pppd[617]: local IP address xxx.xxx.xxx.xxx
Apr 18 16:54:58 daemon pppd[617]: remote IP address 195.166.128.186
Apr 18 16:54:58 daemon pppd[617]: primary DNS address 212.159.6.10
Apr 18 16:54:58 daemon pppd[617]: secondary DNS address 212.159.6.9
Apr 18 16:54:58 daemon pppd[617]: Received valid IP address from server. Connection UP.
Apr 18 16:54:58 user syslog: begin: interface: ppp_0_0_38_1 go to up
Apr 18 16:54:59 daemon UPNPD[16247]: received signal 15, good-bye
Apr 18 16:55:01 daemon UPNPD[17041]: HTTP listening on port 2800
Apr 18 16:55:05 user syslog: end: interface: ppp_0_0_38_1 go to up
Apr 18 16:56:44 daemon pppd[617]: No response to 6 echo-requests
Apr 18 16:56:44 daemon pppd[617]: Serial link appears to be disconnected.
Apr 18 16:56:44 daemon pppd[617]: Clear IP addresses. Connection DOWN.
Apr 18 16:56:44 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:56:44 daemon pppd[617]: Connection terminated.
Apr 18 16:56:44 daemon pppd[617]: Connect time 2.5 minutes.
Apr 18 16:56:44 daemon pppd[617]: Sent 32774 bytes, received 11633 bytes.
Apr 18 16:56:44 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=4
Apr 18 16:56:44 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Apr 18 16:56:44 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Apr 18 16:56:44 user kernel: after reset to 0, dev->refcnt=0
Apr 18 16:56:44 user syslog: begin: interface: ppp_0_0_38_1 go to down
Apr 18 16:56:44 user syslog: end: interface: ppp_0_0_38_1 go to down
Apr 18 16:56:47 daemon pppd[617]: PPP: Start to connect ...
Apr 18 16:56:49 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 16:56:49 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 16:56:49 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:56:55 daemon pppd[617]: PPP LCP UP.
Apr 18 16:56:56 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:57:05 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 16:57:05 daemon pppd[617]: Connection terminated.
Apr 18 16:57:08 daemon pppd[617]: PPP: Start to connect ...
Apr 18 16:57:09 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 16:57:09 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 16:57:09 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:57:18 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 16:57:18 daemon pppd[617]: Connection terminated.
Apr 18 16:57:21 daemon pppd[617]: PPP: Start to connect ...
Apr 18 16:57:23 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 16:57:23 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 16:57:23 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:57:32 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 16:57:32 daemon pppd[617]: Connection terminated.
Apr 18 16:57:35 daemon pppd[617]: PPP: Start to connect ...
Apr 18 16:57:37 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 16:57:37 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 16:57:37 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:57:37 daemon pppd[617]: PPP LCP UP.
Apr 18 16:58:22 daemon pppd[617]: LCP terminated by peer
Apr 18 16:58:22 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:58:25 daemon pppd[617]: Connection terminated.
Apr 18 16:58:28 daemon pppd[617]: PPP: Start to connect ...
Apr 18 16:58:30 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 16:58:30 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 16:58:30 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:58:30 daemon pppd[617]: PPP LCP UP.
Apr 18 16:59:40 daemon pppd[617]: No response to 6 echo-requests
Apr 18 16:59:40 daemon pppd[617]: Serial link appears to be disconnected.
Apr 18 16:59:40 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 16:59:46 daemon pppd[617]: Connection terminated.
Apr 18 16:59:49 daemon pppd[617]: PPP: Start to connect ...
Apr 18 16:59:51 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 16:59:51 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 16:59:51 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:00:00 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 17:00:00 daemon pppd[617]: Connection terminated.
Apr 18 17:00:03 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:00:05 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:00:05 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:00:05 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:00:11 daemon pppd[617]: PPP LCP UP.
Apr 18 17:00:39 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:00:39 daemon pppd[617]: PPP LCP UP.
Apr 18 17:00:40 daemon pppd[617]: local IP address xxx.xxx.xxx.xxx
Apr 18 17:00:40 daemon pppd[617]: remote IP address 195.166.128.186
Apr 18 17:00:40 daemon pppd[617]: primary DNS address 212.159.6.9
Apr 18 17:00:40 daemon pppd[617]: secondary DNS address 212.159.6.10
Apr 18 17:00:40 daemon pppd[617]: Received valid IP address from server. Connection UP.
Apr 18 17:00:40 user syslog: begin: interface: ppp_0_0_38_1 go to up
Apr 18 17:00:40 daemon UPNPD[17041]: received signal 15, good-bye
Apr 18 17:00:43 daemon UPNPD[18632]: HTTP listening on port 2800
Apr 18 17:00:47 user syslog: end: interface: ppp_0_0_38_1 go to up
Apr 18 17:07:49 daemon pppd[617]: No response to 6 echo-requests
Apr 18 17:07:49 daemon pppd[617]: Serial link appears to be disconnected.
Apr 18 17:07:49 daemon pppd[617]: Clear IP addresses. Connection DOWN.
Apr 18 17:07:49 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:07:49 user kernel: Line 0: ADSL link down
Apr 18 17:07:49 user syslog: tc qdisc del dev ppp_0_0_38_1 root 2>/dev/null
Apr 18 17:07:51 user kernel: Line 0: xDSL G.994 training
Apr 18 17:07:55 daemon pppd[617]: Connection terminated.
Apr 18 17:07:55 daemon pppd[617]: Connect time 7.8 minutes.
Apr 18 17:07:55 daemon pppd[617]: Sent 789028 bytes, received 3261054 bytes.
Apr 18 17:07:55 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=8
Apr 18 17:07:55 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Apr 18 17:07:55 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Apr 18 17:07:55 user kernel: after reset to 0, dev->refcnt=0
Apr 18 17:07:59 user kernel: Line 0: ADSL G.992 started
Apr 18 17:08:04 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:08:10 user kernel: Line 0: ADSL G.992 message exchange
Apr 18 17:08:11 user kernel: Line 0: ADSL link down
Apr 18 17:08:14 user kernel: Line 0: xDSL G.994 training
Apr 18 17:08:23 user kernel: Line 0: ADSL G.992 started
Apr 18 17:08:27 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:08:33 user kernel: Line 0: ADSL G.992 message exchange
Apr 18 17:08:34 user kernel: Line 0: ADSL link up, Path 0, us=971, ds=3766
Apr 18 17:08:37 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:08:38 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:08:38 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:08:38 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:08:47 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 17:08:47 daemon pppd[617]: Connection terminated.
Apr 18 17:08:49 user syslog: web: ::ffff:192.168.1.100 login
Apr 18 17:08:50 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:08:52 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:08:52 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:08:52 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:08:52 daemon pppd[617]: PPP LCP UP.
Apr 18 17:08:53 daemon pppd[617]: local IP address xxx.xxx.xxx.xxx
Apr 18 17:08:53 daemon pppd[617]: remote IP address 195.166.128.188
Apr 18 17:08:53 daemon pppd[617]: primary DNS address 212.159.6.10
Apr 18 17:08:53 daemon pppd[617]: secondary DNS address 212.159.6.9
Apr 18 17:08:53 daemon pppd[617]: Received valid IP address from server. Connection UP.
Apr 18 17:08:53 user syslog: begin: interface: ppp_0_0_38_1 go to up
Apr 18 17:08:54 daemon dnsmasq[87]: using nameserver 8.8.4.4#53
Apr 18 17:08:54 daemon dnsmasq[87]: using nameserver 8.8.8.8#53
Apr 18 17:08:54 daemon UPNPD[18632]: received signal 15, good-bye
Apr 18 17:08:56 daemon UPNPD[19897]: HTTP listening on port 2800
Apr 18 17:09:01 user syslog: end: interface: ppp_0_0_38_1 go to up
Apr 18 17:21:44 user kernel: Line 0: ADSL link down
Apr 18 17:21:44 user syslog: tc qdisc del dev ppp_0_0_38_1 root 2>/dev/null
Apr 18 17:21:46 user kernel: Line 0: xDSL G.994 training
Apr 18 17:21:47 daemon pppd[617]: Terminating connection due to link down.
Apr 18 17:21:54 user kernel: Line 0: ADSL G.992 started
Apr 18 17:21:59 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:22:05 user kernel: Line 0: ADSL link down
Apr 18 17:22:09 user kernel: Line 0: xDSL G.994 training
Apr 18 17:22:18 user kernel: Line 0: ADSL G.992 started
Apr 18 17:22:22 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:22:29 user kernel: Line 0: ADSL link up, Path 0, us=1011, ds=9529
Apr 18 17:22:32 daemon pppd[617]: Clear IP addresses. Connection DOWN.
Apr 18 17:22:32 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:22:38 daemon pppd[617]: Connection terminated.
Apr 18 17:22:38 daemon pppd[617]: Connect time 13.7 minutes.
Apr 18 17:22:38 daemon pppd[617]: Sent 1024622 bytes, received 7692716 bytes.
Apr 18 17:22:38 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=4
Apr 18 17:22:39 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Apr 18 17:22:39 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Apr 18 17:22:39 user kernel: after reset to 0, dev->refcnt=0
Apr 18 17:22:39 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:22:40 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:22:40 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:22:40 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:22:41 daemon pppd[617]: PPP LCP UP.
Apr 18 17:22:57 daemon pppd[617]: LCP terminated by peer
Apr 18 17:22:57 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:23:00 daemon pppd[617]: Connection terminated.
Apr 18 17:23:03 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:23:05 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:23:05 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:23:05 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:23:05 daemon pppd[617]: PPP LCP UP.
Apr 18 17:23:06 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:23:06 daemon pppd[617]: PPP LCP UP.
Apr 18 17:23:06 daemon pppd[617]: local IP address xxx.xxx.xxx.xxx
Apr 18 17:23:06 daemon pppd[617]: remote IP address 195.166.128.190
Apr 18 17:23:06 daemon pppd[617]: primary DNS address 212.159.6.10
Apr 18 17:23:06 daemon pppd[617]: secondary DNS address 212.159.6.9
Apr 18 17:23:06 daemon pppd[617]: Received valid IP address from server. Connection UP.
Apr 18 17:23:06 user syslog: begin: interface: ppp_0_0_38_1 go to up
Apr 18 17:23:07 daemon dnsmasq[87]: using nameserver 8.8.4.4#53
Apr 18 17:23:07 daemon dnsmasq[87]: using nameserver 8.8.8.8#53
Apr 18 17:23:07 daemon UPNPD[19897]: received signal 15, good-bye
Apr 18 17:23:09 daemon UPNPD[21238]: HTTP listening on port 2800
Apr 18 17:23:14 user syslog: end: interface: ppp_0_0_38_1 go to up
Apr 18 17:24:53 user kernel: Line 0: ADSL link down
Apr 18 17:24:54 user syslog: tc qdisc del dev ppp_0_0_38_1 root 2>/dev/null
Apr 18 17:24:54 daemon pppd[617]: Terminating connection due to link down.
Apr 18 17:24:55 user kernel: Line 0: xDSL G.994 training
Apr 18 17:25:04 user kernel: Line 0: ADSL G.992 started
Apr 18 17:25:08 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:25:14 user kernel: Line 0: ADSL G.992 message exchange
Apr 18 17:25:15 user kernel: Line 0: ADSL link down
Apr 18 17:25:18 user kernel: Line 0: xDSL G.994 training
Apr 18 17:25:27 user kernel: Line 0: ADSL G.992 started
Apr 18 17:25:31 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:25:38 user kernel: Line 0: ADSL link up, Path 0, us=960, ds=3680
Apr 18 17:25:42 daemon pppd[617]: Clear IP addresses. Connection DOWN.
Apr 18 17:25:42 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:25:48 daemon pppd[617]: Connection terminated.
Apr 18 17:25:48 daemon pppd[617]: Connect time 2.7 minutes.
Apr 18 17:25:48 daemon pppd[617]: Sent 63860 bytes, received 110628 bytes.
Apr 18 17:25:48 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=4
Apr 18 17:25:48 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Apr 18 17:25:48 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Apr 18 17:25:48 user kernel: after reset to 0, dev->refcnt=0
Apr 18 17:25:48 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:25:49 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:25:49 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:25:49 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:25:58 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 17:25:58 daemon pppd[617]: Connection terminated.
Apr 18 17:25:59 user kernel: Line 0: ADSL link down
Apr 18 17:26:00 user syslog: tc qdisc del dev ppp_0_0_38_1 root 2>/dev/null
Apr 18 17:26:01 user kernel: Line 0: xDSL G.994 training
Apr 18 17:26:09 user kernel: Line 0: ADSL G.992 started
Apr 18 17:26:14 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:26:20 user kernel: Line 0: ADSL G.992 message exchange
Apr 18 17:26:21 user kernel: Line 0: ADSL link down
Apr 18 17:26:24 user kernel: Line 0: xDSL G.994 training
Apr 18 17:26:33 user kernel: Line 0: ADSL G.992 started
Apr 18 17:26:37 user kernel: Line 0: ADSL G.992 channel analysis
Apr 18 17:26:44 user kernel: Line 0: ADSL link up, Path 0, us=993, ds=5319
Apr 18 17:26:47 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:26:48 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:26:48 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:26:48 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:26:49 daemon pppd[617]: PPP LCP UP.
Apr 18 17:27:22 daemon pppd[617]: LCP terminated by peer
Apr 18 17:27:22 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:27:25 daemon pppd[617]: Connection terminated.
Apr 18 17:27:28 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:27:30 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:27:30 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:27:30 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:27:30 daemon pppd[617]: PPP LCP UP.
Apr 18 17:27:31 daemon pppd[617]: local IP address xxx.xxx.xxx.xxx
Apr 18 17:27:31 daemon pppd[617]: remote IP address 195.166.128.196
Apr 18 17:27:31 daemon pppd[617]: primary DNS address 212.159.6.10
Apr 18 17:27:31 daemon pppd[617]: secondary DNS address 212.159.6.9
Apr 18 17:27:31 daemon pppd[617]: Received valid IP address from server. Connection UP.
Apr 18 17:27:32 user syslog: begin: interface: ppp_0_0_38_1 go to up
Apr 18 17:27:32 daemon dnsmasq[87]: using nameserver 8.8.4.4#53
Apr 18 17:27:32 daemon dnsmasq[87]: using nameserver 8.8.8.8#53
Apr 18 17:27:32 daemon UPNPD[21238]: received signal 15, good-bye
Apr 18 17:27:34 daemon UPNPD[23161]: HTTP listening on port 2800
Apr 18 17:27:39 user syslog: end: interface: ppp_0_0_38_1 go to up
Apr 18 17:38:44 syslog -- MARK --
Apr 18 17:39:30 daemon pppd[617]: No response to 6 echo-requests
Apr 18 17:39:30 daemon pppd[617]: Serial link appears to be disconnected.
Apr 18 17:39:30 daemon pppd[617]: Clear IP addresses. Connection DOWN.
Apr 18 17:39:30 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:39:31 user syslog: begin: interface: ppp_0_0_38_1 go to down
Apr 18 17:39:31 user syslog: end: interface: ppp_0_0_38_1 go to down
Apr 18 17:39:36 daemon pppd[617]: Connection terminated.
Apr 18 17:39:36 daemon pppd[617]: Connect time 12.1 minutes.
Apr 18 17:39:36 daemon pppd[617]: Sent 325089 bytes, received 373954 bytes.
Apr 18 17:39:36 user kernel: dev_shutdown, dec ppp device refcnt, dev->refcnt=4
Apr 18 17:39:37 user kernel: unregister_netdevice: waiting for ppp_0_0_38_1 to become free. Usage count = -1
Apr 18 17:39:37 user kernel: dev->name = ppp_0_0_38_1, dev->refcnt=-1
Apr 18 17:39:37 user kernel: after reset to 0, dev->refcnt=0
Apr 18 17:39:40 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:39:41 daemon UPNPD[23161]: ioctl(s, SIOCGIFADDR, ...): No such device
Apr 18 17:39:41 daemon UPNPD[23161]: Failed to get ip address for interface ppp_0_0_38_1
Apr 18 17:39:41 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:39:41 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:39:41 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:39:50 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 17:39:50 daemon pppd[617]: Connection terminated.
Apr 18 17:39:53 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:39:55 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:39:55 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:39:55 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:39:55 daemon pppd[617]: PPP LCP UP.
Apr 18 17:39:59 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:40:08 daemon pppd[617]: LCP: timeout sending Config-Requests
Apr 18 17:40:08 daemon pppd[617]: Connection terminated.
Apr 18 17:40:11 daemon pppd[617]: PPP: Start to connect ...
Apr 18 17:40:13 daemon pppd[617]: Using interface ppp0_0_38_1
Apr 18 17:40:13 daemon pppd[617]: Connect: ppp_0_0_38_1 <-->
Apr 18 17:40:13 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:40:18 daemon pppd[617]: PPP LCP UP.
Apr 18 17:40:19 daemon pppd[617]: Couldn't increase MTU to 1500.
Apr 18 17:40:19 daemon pppd[617]: PPP LCP UP.
Apr 18 17:40:20 daemon pppd[617]: local IP address xxxx.xxxx.xxxx.xxxx
Apr 18 17:40:20 daemon pppd[617]: remote IP address 195.166.128.189
Apr 18 17:40:20 daemon pppd[617]: primary DNS address 212.159.6.9
Apr 18 17:40:20 daemon pppd[617]: secondary DNS address 212.159.6.10
Apr 18 17:40:20 daemon pppd[617]: Received valid IP address from server. Connection UP.
Apr 18 17:40:20 user syslog: begin: interface: ppp_0_0_38_1 go to up
Apr 18 17:40:21 daemon UPNPD[23161]: received signal 15, good-bye
Apr 18 17:40:23 daemon UPNPD[24299]: HTTP listening on port 2800
Apr 18 17:40:27 user syslog: end: interface: ppp_0_0_38_1 go to up
Steve
Steve
Message 1 of 4
(1,137 Views)
3 REPLIES 3
18-04-2014 6:20 PM
Hi Steve,
The router cannot get synch up and establsh ppp session to PN. Can you try the following...
1. Quiet line test - dial 17070 option 2 - line should be quiet. If there is noise on the line raise a adult report with your phone service provider. You might find tat making a call to your home number and letting it ring could give temporary relief if there is noise.
2. Change the filter.
3. Try the router connected to the master socket.
If this makes no difference raise / follow the fault reporter here - http://faults.plus.net
HTH until the DCT guys are around on Tuesday.
Message 2 of 4
(709 Views)
18-04-2014 6:22 PM
I have found that the Billion 7800 series seem to occasionally lose or corrupt it's supposedly non-volatile configuration settings, causing inexplicable connection problems like what you are describing.
I have found the only reliable solution is to reset the device to factory defaults, cleanly reconfigure all settings from scratch, "Save Config", then wait a few seconds and then reboot the gateway. On restart it will work perfectly, and will continue working for many months.
Since powering my 7800 via an uninterruptable mains power supply I haven't needed to reconfigure my unit, so I have my suspicions that these devices are susceptible to mains power spikes or glitches - so you might want to do the same, or at least use a surge protected extension lead.
You might also want to read this previous thread - https://community.plus.net/forum/index.php/topic,117883.0.html
Message 3 of 4
(709 Views)
18-04-2014 7:51 PM
I did the quiet line test and there was audible hiss so removed the nte5 faceplate & plugged directly into the test socket no hiss so either filter or the 2m of extension wiring was faulty, turns out it was the later although why it's suddenly caused a problem is a mystery.
The only reason there's 2m of extension is when the council fitted central heating the only place to put the radiator was right next to the BT master socket,,,, hopefully if i decide to go for fibre I can get BT to reposition the master closer to where the line enters the house.
Prior to removing the extension:
Upstream 993
Downstream 5319
SNR Margin(Upstream) 5.8
SNR Margin(Downstream) 19.4
Line Attenuation(Upstream) 26.8
Line Attenuation(Downstream) 43.5
After
Upstream 1024
Downstream 9959
SNR Margin(Upstream) 5.7
SNR Margin(Downstream) 6.0
Line Attenuation(Upstream) 26.6
Line Attenuation(Downstream) 43.0
Hopefully that's how it will stay, many thanks to both of you for your help.
Steve
Edit: Wasn't my wiring at fault - the extension box was jammed full of spiders & other insects mostly dead.......
Upstream 993
Downstream 5319
After
Upstream 1024
Downstream 9959
Steve
Message 4 of 4
(709 Views)
