connection problem
xxandy77xx
connection problem
Hi ,
I have just had a 4/5 disconnects in the space of  about 10 mins  after having a stable line for a few days i thought all was good Sad  could someone check this for me  thank you .
1 REPLY
Re: connection problem
I've checked over your line and can see the bout of disconnections you had last night;
<img src="http://community.plus.net/visualradius/generated/image13806135232467.png"/>
Everything seems to be ok now. I'd suggest monitoring your connection and if it was to happen again then run through our faults troubleshooter.
