connection keeps losing
- connection keeps losing
20-03-2009 11:24 AM
Re: connection keeps losing
20-03-2009 11:29 AM
There's no known issues on your exchange from what I can tell.
How often is your connection dropping? I can only see one drop in the last 2.5 days?
20-03-2009 11:40 AM
ping preferred dns server: fail, Just tested it now and it passed all tests, but sometimes icon in tray says ' wireless connection low' and even can show icons red with not connection, hope its not my router.
20-03-2009 11:42 AM
It's likely to be the signal strength of your wireless connection. Are you in a position where you can use a wired connection from your computer to your router instead? I suspect that will completely solve all of your problems.
20-03-2009 11:52 AM
20-03-2009 11:55 AM
Are you able to try using a different wireless channel on your router?
20-03-2009 12:06 PM
Thanks for help.
20-03-2009 12:41 PM
20-03-2009 12:52 PM
regards, Fenster.
20-03-2009 1:17 PM
If you can, try using channel 1. Hopefully this will improve the signal that your computer is getting from your router.
20-03-2009 3:50 PM
20-03-2009 3:55 PM
20-03-2009 4:15 PM
