connection keeps going off
- connection keeps going off
27-04-2025 12:52 PM
my internet connection keeps dropping out..it will do it a few times over say 10 mins then be ok for a while then off and on again..doing it every day.. any ideas anyone..are plusnet having problems?
Message 1 of 2
(366 Views)
1 REPLY 1
Re: connection keeps going off
27-04-2025 10:32 PM
PlusNet are not, as a whole, having problems.
Do you have multiple devices experiencing this problem?
Also check the PlusNet router logs, see if there’s anything showing up to indicate something.
That's RPM to you!!
Message 2 of 2
(273 Views)
