connection issues
- Re: connection issues
connection issues
26-07-2014 11:11 AM
So the past few days I've had a huge number of disconnections which seemed to happen in the morning this graph from yesterday:
and today:
I have reset the bt router/plusnet router once and manually tried connecting a few times when the disconnections occured. I've checked the phone line today and it's completely dead, can't dial it or dial out with it. I've read somewhere on the bt forums that it could possibly be due to a thunderstorm which could damage the components inside the masterplate. And since we had a thunderstorm with some rain yesterday in the morning this seems pretty plausible.
So I'm wondering on what I should be doing, I guess contact bt report the fault? though their support is pretty terrible
Hope someone can shed some light on this
and today:
Message 1 of 5
(868 Views)
4 REPLIES 4
26-07-2014 11:14 AM
Raise a fault here - assuming that you are actually with Plusnet - https://faults.plus.net as you can't contact BT Openreach directly
Message 2 of 5
(551 Views)
26-07-2014 11:16 AM
Hi there
If the phone lines completely dead this needs investigating first I'm afraid.
We can't report any issues with your connection until this is fixed
I'd recommend getting in touch with your phone provider
Message 3 of 5
(551 Views)
26-07-2014 11:16 AM
You need to report your phone fault to your phone provider - assuming bt from your post?
That'll need to be sorted before your broadband be looked at.
Message 4 of 5
(551 Views)
26-07-2014 11:27 AM
Ok, thanks I'll report it to BT then
Message 5 of 5
(551 Views)
