connection graph
jasonfreeman
connection graph
Can someone from plusnet post a graph of my connection over the past couple of days please?
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: connection graph
Here the graph, as requested:
<img src="http://community.plus.net/visualradius/generated/image13927257059041.png"/>
Chris Pettitt
Cloud Environments Engineer
jasonfreeman
Looking at that graph would you say that's a bad graph, an ok graph or a good graph?
Plusnet Staff
Plusnet Staff
Fixes: 5
It doesn't look particularly bad.
Are any of the disconnections you testing anything at all?
Chris Pettitt
jasonfreeman
No, I've just left it to do its job
Fixes: 62
Have you checked your router log as that would identify what type of disconnection it is and when
Also the engineer visit isn't until tomorrow
jasonfreeman
How do I check the router log?
Fixes: 62
look at the left hand menu - Event Logs
http://192.168.1.254/cgi/b/ST/?be=0&l0=1&l1=-1
Plusnet Staff
Plusnet Staff
Fixes: 5
To me, it doesn't look too bad, but I still think we're best off re-assessing the situation after the engineer visit as there are a couple of drops.
Chris Pettitt
jasonfreeman
Ok thank you chris and I will re-post when I have checked the event log
jasonfreeman
Could someone post a graph of my broadband connetion please to see how it is now after the engineer work?
Plusnet Staff
Plusnet Staff
Fixes: 5
Here's your connection graph:
<img src="http://community.plus.net/visualradius/generated/image13929931197613.png"/>
Chris Pettitt
jasonfreeman
After tha engineers work on wednesday my connection looks better than before because the only time it closed is when I restarted my router yesterday so that rotten old cable was the problem right?
