connection failed with error 651
- connection failed with error 651
17-05-2011 8:56 AM
The modem (or other connecting device) has reported an error.
Re: connection failed with error 651
17-05-2011 9:11 AM
Quote Windows Error 651 are caused by misconfigured system files.
So, from my experience, If you got Windows Error 651 then there is a 96% chance that your computer has registry problems.
The Windows Error 651 are easy to repair. By downloading and running the registry repair tool WiseFixer, you can quickly and effectively fix this problem and prevent others from occuring. Simply click the links below for your free download.
http://www.wisefixer.com/lp/?kw=error-651&gclid=CJPs_uXE7qgCFYob4QodVhOVCw
17-05-2011 9:19 AM
17-05-2011 9:31 AM
17-05-2011 9:56 AM
17-05-2011 9:59 AM
17-05-2011 10:15 AM
Quote from: djpinky Can anyone tell me why i get this error code when trying to connect ?
Connect to what, exactly? Are you using a broadband modem? These are very outdated now, you would be better off getting a router and Plusnet will give you a free one.
17-05-2011 10:17 AM
O our wonderful god-fearing, mother- friends over the Pond!
17-05-2011 10:30 AM
17-05-2011 11:21 AM
The error you have encountered seems to be something to do with a dial-up modem, so perhaps your computer is not trying to connect in the right way. Open up Internet Options, either from Control Panel or from the bottom of the Tools menu in Internet Explorer. Click on the 'Connections' tab and make sure 'Never dial a connection' is selected. Whilst you are about it, click the 'LAN settings' button and make sure the option to use a proxy server is NOT selected.
17-05-2011 12:44 PM
17-05-2011 3:34 PM
17-05-2011 3:36 PM
