connection down
bez1
connection down
Anyone else having connection problems in Shirebrook area. thanks
4 REPLIES 4
Aspiring Legend
Fixes: 198
Re: connection down
Welcome to the forums, @bez1  . If you would like help from the community, it would be a good idea to follow this guide: https://community.plus.net/t5/ADSL-Broadband/ADSL-Speed-faults/m-p/1270245#M297501 , reporting back with as much of the requested information as possible. A 'Quiet Line Test' - dial 17070 from a landline, preferably corded, phone and select option 2 - could also help. There should be no noise on the line - if there is, report a phone fault to whoever you pay for your phone service.
bez1
Re: connection down
Thanks for answering, I know how to check the gear thanks just wondered how local the problem was. Appreciate the answer, thanks again.
Aspiring Legend
Fixes: 198
Re: connection down
No problem then - to be honest, it is more than likely just you, otherwise there  would be more reports.
bez1
Re: connection down
ok thanks, will try contacting support.
