connection cut out and I can't connect back!! help
ashrafmiah93
Nicely enjoyin watching a programme on bbc iplayer and I get disconnected (green broadband light going offf. Gives me a message saying authentication failed. So I type in the ip address and try connect through the thompson gateway page it connects but I can visit any pages it just loads continuously. It either connects or it doesn't. ?
Fixes: 46
Re: connection cut out and I can't connect back!! help
Possibly due to the BT maintenance mentioned in this http://usertools.plus.net/status/archive/1332758911.htm Service Status notice. Work should be complete by 6am.
David
ashrafmiah93
Quote from: spraxyt
Thanks! But wouldn't it be helpful to send an email to customers regarding things like this for heads up?
Anyway, do I require a reboot of my router tomorrow? Maybe around 11am as this is the perfect time for a reboot after my last experience rebooting before sunrise cuases a slow speed
Fixes: 46
If you want to receive email Service Status notifications you can sign up at http://usertools.plus.net/status/email.php.
Your router shouldn't have lost sync with the exchange so a reboot isn't necessary. It should reconnect itself when routing is restored but if it doesn't logging into the router's web interface and clicking Connect is suggested.
David
