connecting hudl to router
davey32
Hi as anyone had trouble connecting a hudl to router.
Have done the capital etter password bit, and my hudlregisters good signal, but hen comes up with authenticty problem.
Thanks.
Fixes: 55
Re: connecting hudl to router
Sounds like you might be using the Router Access Password rather than the Wireless Network key as printed on the card supplied with your router.
DerwentMailman
My Hudl connects to my D-Link router without issue using the Wireless password I set up rather than using the password to access my router as suggested by the previous poster.
