conection speed slower now ive change my plusnet package :(
- conection speed slower now ive change my plusnet p...
08-10-2007 8:16 PM
any ideas why ?
thanks
Re: conection speed slower now ive change my plusnet package :(
08-10-2007 8:34 PM
Are the figures you quoted your sync speed or the speed you get with a speed tester?
Can you post your full line stats (line attenuation & SNR/margin)
What does it say under high speed broadband on the portal (under connection settings).
What does www.speedtester.bt.com say, post the full report.
08-10-2007 9:03 PM
08-10-2007 9:07 PM
08-10-2007 9:11 PM
08-10-2007 9:13 PM
08-10-2007 9:14 PM
There is usually a status page which shows sync speed and line stats. How to find this on some common routers is here.
Also run the BT speedtest I linked to.
08-10-2007 9:16 PM
08-10-2007 9:26 PM
these numbers change though
tried bt speed test and server is down
ps:im using bt voyager 105 till my new wireless router comes
08-10-2007 10:02 PM
The link to Kitz's website explains how to get them.
08-10-2007 10:13 PM
08-10-2007 10:29 PM
09-10-2007 9:36 AM
This recent change (from 2000Kbps to 1500Kbps from what I can tell) isn't related to your account change, but merely a slight blip in sync speeds.
Look at your line history over the last couple of weeks, it has been fluctuating between 1500Kbps and 2000Kbps, so this shouldn't be something unexpected, but more of "one of those things".
