clarkRec speed problem
clarkrec
My upload speed is really slow as well with the Technicolor TG582b router.
Could you upgrade my firmware please if you think this would help?
Also not sure if the upload speed has been capped as with some other peoples - if it has could it be uncapped please?
Plusnet Staff
Plusnet Staff
Fixes: 159
Your upload speed is already showing as uncapped. What upload speeds are you getting?
 Chris Parr
 Plusnet Staff
Fixes: 10
Could you post the information from http://192.168.1.254/cgi/b/dsl/dt/?be=0&l0=2&l1=0 please.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
clarkrec
Just run a speedtest.net test and getting 0.52mbps upload speed - get the same result whether on wireless or plugged directly into the router.
Any other ideas what could be causing this?
Fixes: 10
That could be a perfectly normal result depending upon how far you are from the exchange. Please post the stats I asked for in my last post.
clarkrec
Ah sorry didn't see that, see below:
DSL Connection
Link Information
Uptime:7 days, 3:13:24
DSL Type:ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]:888 / 9,383
Data Transferred (Sent/Received) [MB/GB]:863.00 / 6.93
Output Power (Up/Down) [dBm]:12.7 / 0.0
Line Attenuation (Up/Down) [dB]:21.1 / 41.5
SN Margin (Up/Down) [dB]:11.9 / 9.1
System Vendor ID (Local/Remote):TMMB / ----
Chipset Vendor ID (Local/Remote):BDCM / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):-
Error Seconds (Local/Remote):568,786 / 75
FEC Errors (Up/Down):87,837 / 414,686,614
CRC Errors (Up/Down):3,512,498 / 36,269,972
HEC Errors (Up/Down):1,175,485 / 21,068,425
I don't think it's a perfectly normal result as never had a problem with this before, but recently uploading anything just takes ages!
Fixes: 62
That is a bit odd as I get about 700kbps with an 888kbps sync
Can you check here http://www.thinkbroadband.com/ - speedtest on the left and here http://www.mybroadbandspeed.co.uk/
Having said that your upstream CRC errors are pretty horrible which may be part of the problem
These are mine after 14 days
FEC Errors (Up/Down): 20,907 / 643,947
CRC Errors (Up/Down): 277 / 5,172
HEC Errors (Up/Down): 522 / 96,246
Fixes: 10
There's a lot of errors being logged - I wonder if that is is affecting the throughput?
Upgrading the firmware may not be such a silly idea.
clarkrec
This is the thinkbroadband result: http://www.thinkbroadband.com/speedtest/results.html?id=1422711458309395655
And mybroadbandspeed.co.uk gives a download speed of 7648kbps and an upload speed of 558kbps.
Does this give any more ideas? If upgrading the firmware might help then is someone able to do this for me please?
jim:green image added mod:end
Fixes: 62
This is mine - note the difference in upload speed result
If you dial 17070 option 2 is the line quiet
Fixes: 62
Re: clarkRec speed problem
Topic split off to it's own thread
clarkrec
Yes, the line is quiet when I try that.
The only thing I can think of other than firmware upgrade is that we have a couple of signal boosters plugged in otherwise the wireless signal was very weak - is it possible that these could be impacting negatively at all?
If so, I will try and take them back out tonight and see if that changes any results.
Thanks for all the help so far.
Fixes: 10
It would be interesting to see what you get using a wired connection with the boosters turned off. If you could take a copy of the stats before and after so we can see how many errors are logged while you run the test.
clarkrec
Right, this was before I took the boosters out:
Uptime: 7 days, 9:19:55
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 9,383
Data Transferred (Sent/Received) [MB/GB]: 899.37 / 7.16
Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 21.1 / 41.5
SN Margin (Up/Down) [dB]: 11.7 / 8.6
Loss of Link (Remote): -
Error Seconds (Local/Remote): 589,945 / 81
FEC Errors (Up/Down): 87,837 / 589,770,129
CRC Errors (Up/Down): 3,643,049 / 37,618,420
HEC Errors (Up/Down): 1,219,071 / 21,859,560
And this was after:
Uptime: 0 days, 0:02:12
Bandwidth (Up/Down) [kbps/kbps]: 888 / 8,714
Data Transferred (Sent/Received) [MB/MB]: 1.86 / 16.90
Line Attenuation (Up/Down) [dB]: 21.1 / 41.0
SN Margin (Up/Down) [dB]: 12.4 / 10.1
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 85
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 43
Did a speedtest without the boosters and the speed improved to 0.76, so looks as if these may be the problem. Are these errors still unusually high or are they reasonable?
Thanks for all the advice
Fixes: 62
You weren't supposed reboot/reconnect the router
Please leave things alone now and report the stats again tomorrow evening
However please do a Thinkbroadband speed test and report the result as it may show if things have changed
