clarkRec speed problem
- clarkRec speed problem
31-01-2015 10:07 AM
Could you upgrade my firmware please if you think this would help?
Also not sure if the upload speed has been capped as with some other peoples - if it has could it be uncapped please?
31-01-2015 10:17 AM
31-01-2015 10:29 AM
31-01-2015 10:42 AM
Any other ideas what could be causing this?
31-01-2015 11:29 AM
31-01-2015 12:35 PM
DSL Connection
Link Information
Uptime:7 days, 3:13:24
DSL Type:ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]:888 / 9,383
Data Transferred (Sent/Received) [MB/GB]:863.00 / 6.93
Output Power (Up/Down) [dBm]:12.7 / 0.0
Line Attenuation (Up/Down) [dB]:21.1 / 41.5
SN Margin (Up/Down) [dB]:11.9 / 9.1
System Vendor ID (Local/Remote):TMMB / ----
Chipset Vendor ID (Local/Remote):BDCM / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):-
Error Seconds (Local/Remote):568,786 / 75
FEC Errors (Up/Down):87,837 / 414,686,614
CRC Errors (Up/Down):3,512,498 / 36,269,972
HEC Errors (Up/Down):1,175,485 / 21,068,425
I don't think it's a perfectly normal result as never had a problem with this before, but recently uploading anything just takes ages!
31-01-2015 1:18 PM
Can you check here http://www.thinkbroadband.com/ - speedtest on the left and here http://www.mybroadbandspeed.co.uk/
Having said that your upstream CRC errors are pretty horrible which may be part of the problem
These are mine after 14 days
FEC Errors (Up/Down): 20,907 / 643,947
CRC Errors (Up/Down): 277 / 5,172
HEC Errors (Up/Down): 522 / 96,246
31-01-2015 1:24 PM
Upgrading the firmware may not be such a silly idea.
31-01-2015 1:44 PM
And mybroadbandspeed.co.uk gives a download speed of 7648kbps and an upload speed of 558kbps.
Does this give any more ideas? If upgrading the firmware might help then is someone able to do this for me please?
jim:green image added mod:end
31-01-2015 1:48 PM
If you dial 17070 option 2 is the line quiet
Re: clarkRec speed problem
31-01-2015 1:52 PM
31-01-2015 2:01 PM
The only thing I can think of other than firmware upgrade is that we have a couple of signal boosters plugged in otherwise the wireless signal was very weak - is it possible that these could be impacting negatively at all?
If so, I will try and take them back out tonight and see if that changes any results.
Thanks for all the help so far.
31-01-2015 2:17 PM
31-01-2015 7:22 PM
Uptime: 7 days, 9:19:55
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 9,383
Data Transferred (Sent/Received) [MB/GB]: 899.37 / 7.16
Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 21.1 / 41.5
SN Margin (Up/Down) [dB]: 11.7 / 8.6
Loss of Link (Remote): -
Error Seconds (Local/Remote): 589,945 / 81
FEC Errors (Up/Down): 87,837 / 589,770,129
CRC Errors (Up/Down): 3,643,049 / 37,618,420
HEC Errors (Up/Down): 1,219,071 / 21,859,560
And this was after:
Uptime: 0 days, 0:02:12
Bandwidth (Up/Down) [kbps/kbps]: 888 / 8,714
Data Transferred (Sent/Received) [MB/MB]: 1.86 / 16.90
Line Attenuation (Up/Down) [dB]: 21.1 / 41.0
SN Margin (Up/Down) [dB]: 12.4 / 10.1
Error Seconds (Local/Remote): 1 / 0
FEC Errors (Up/Down): 0 / 85
CRC Errors (Up/Down): 0 / 2
HEC Errors (Up/Down): 0 / 43
Did a speedtest without the boosters and the speed improved to 0.76, so looks as if these may be the problem. Are these errors still unusually high or are they reasonable?
Thanks for all the advice
31-01-2015 7:26 PM
Please leave things alone now and report the stats again tomorrow evening
However please do a Thinkbroadband speed test and report the result as it may show if things have changed
