chromebook disconnecting - too many stas
gypsyreiver
hi
new customer 2 weeks in. the last week my chromebook is disconnecting with an error too many stas, the only way to connect is to rebook the router.
no issue with pc, laptops or phones...
running on old wbc 10mb line, no ports for fibre in my cabinet.
postcode ne44 6bs
3 REPLIES 3
bobpullen
Fixes: 327
Re: chromebook disconnecting - too many stas
What router are you using and how many wireless clients/devices do you have on your network?
BD
Fixes: 86
Hi @gypsyreiver and welcome to our Community Forum.
I can confirm when looking over your connection from this side currently I can see the signal strength for your given line length looks to be set too low and I beleive then causing errors which are coming across as disconnection and stalled pages your side on the Chromebook. In which case, I've bumped the signal strength on your line back up to where it should be and this should hopefully resolve the issues you've been seeing moving forwards. Please let us know how it goes.
gypsyreiver
Thanks,
Not sure who i know how many connected devices, on BT homehub i could usually see.  Nothing that a family of 5 wouldn;t expect to be honest!
Not sure if related but before 10 download speed was down to 0.2mb. i changed the channel to 1 on the wifi and that seemed to improve things. Will keep an eye on it.
Product name: Plusnet Router
2 - Serial number: N7210741B004890
3 - Firmware version: 7.275.11_F2704N_Plusnet
4 - Board version: F@ST2704N
5 - Mode ADSL
6 - Uptime: 0 days 00:06:30
7 - Data rate: 1179/14707
8 - Maximum data rate: 1180/14704
9 - Noise margin: 5.9/3.1
10 - Line attenuation: 16.3/29.0
12 - Data sent/received: 37.3M/220.9M
20 - Broadband username:
21 - Wi-Fi network/SSID:
22 - Wi-Fi connections: Enable(802.11 b/g/n(up to 144 Mb/s))20 MHz WPS enabled
23 - Wi-Fi security: WPA2
24 - Wi-Fi channel: 1
25 - Firewall: Default
26 - MAC Address: b0:bb:e5:e8:b5:23
27 - Software variant Version 1.0
28 - Boot loader: 7.275.11
Moderator's note by Mike (Mav): Two identical posts released from Spam Filter and one subsequently removed..
