changing to 21CN
- Re: changing to 21CN
changing to 21CN
14-02-2010 1:04 AM
I recieved an E-mail to say I would be changing to 21CN within 5 weeks,that was on 21/12 /09.I know thats only a week or so late but Mand said I would change on the 16/01/10 is it going to happen or is it cancelled. Ted.
Message 1 of 4
(895 Views)
3 REPLIES 3
15-02-2010 2:57 PM
It completed on the 15th Jan, however it was on to ADSL1 on 21CN which allows up to 8Mb speed, if you'd like the up to 20Mb speeds you'll need to switch to Pro or Premium.
Message 2 of 4
(322 Views)
15-02-2010 10:14 PM
Thanks for the quick reply Chris,I didn't know how to tell which I was on (still dont know) but if you say its ,so be it,I must admit that the speed as been very stable over the last few weeks,before that it was very up and down. I dont understand some of the criticisms people put on here I know you cant always be right but every time I have had a problem some one has been here to help,and I speak as a member of quite a lot of years. Better leave it at that sounds like an advert.
Message 3 of 4
(322 Views)
16-02-2010 11:20 AM
Thanks for the positive words, glad you're happy with us.
Message 4 of 4
(322 Views)
