change tcp/udp timeout settings on technicolor tg582n
ghos7em1
is their any way to change timeout settings on this router through cli or edit ini file?
Fixes: 17
Re: change tcp/udp timeout settings on technicolor tg582n
Well, yes, there appears to be a way. Probably the commands under connection timerconfig.
There's an official looking CLI reference (list of all the commands) here: http://www.speedtouch.ca/pdf/TG582n-manual.pdf
Fixes: 102
http://npr.me.uk/telnet.html#timeout may work.
Customer and Forum Moderator.
ghos7em1
thank you
