cant send emails
- cant send emails
cant send emails
16-11-2009 3:15 PM
i cant seem to send any e-mails from outlook express or thunderbird what am i doing wrong, can anyone please help
regards
kev
regards
kev
Message 1 of 8
(1,301 Views)
7 REPLIES 7
Re: cant send emails
16-11-2009 3:22 PM
sorry i forgot to say that i get this message
The message could not be sent because one of the recipients was rejected by the server. The rejected e-mail address was 'xxx_xxxx@o2.co.uk'. Subject 'subframe', Account: 'mail.plus.net', Server: 'relay.plus.net', Protocol: SMTP, Server Response: '550 relay not permitted', Port: 25, Secure(SSL): No, Server Error: 550, Error Number: 0x800CCC79
jim:green email address removed for security mod:end
Message 2 of 8
(744 Views)
Re:cant send emails
16-11-2009 4:11 PM
Is it just to 1 address that you're having problems sending? It looks like that address isn't valid which is why you're seeing the bounce.
Message 3 of 8
(744 Views)
16-11-2009 5:27 PM
no it is all e-mails i try to send. i can recieve e-mails ok but can only send from plusnet webmail
Message 4 of 8
(744 Views)
16-11-2009 5:49 PM
It is just possible that you have set up SSL which isn't supported
Message 5 of 8
(744 Views)
16-11-2009 6:53 PM
i dont wish to be thick but what is ssl and how do i change it
Message 6 of 8
(744 Views)
16-11-2009 6:58 PM
What does http://usertools.plus.net/@gateway say?
B.
B.
Message 7 of 8
(744 Views)
16-11-2009 7:02 PM
http://www.plus.net/support/email/setup/outlook_express.shtml
at the bottom of the page under advanced
Message 8 of 8
(744 Views)
