cant get iplayer on TV but Ok on PC
- cant get iplayer on TV but Ok on PC
05-02-2012 9:12 AM
PLEASE help...I am not am a woman on my own with not one friendly technophile in sight and I have tried everything to get the TV to do what it says on the tin. All signs indicate problem with plusnet router.
What do I do?
Re: cant get iplayer on TV but Ok on PC
05-02-2012 10:12 AM
Please would you check that your TV is supported for iplayer, at
http://iplayerhelp.external.bbc.co.uk/help/where_to_get_iplayer/television/
05-02-2012 10:34 AM
Quote from: suffolkcindy All signs indicate problem with plusnet router.
Which signs exactly, please document them here.
It is not normally necessary to make any changes to a router configuration to accomodate iPlayer on a TV or any other compatible device.
05-02-2012 10:48 AM
have connected my new digital TV to ethernet and there is no automatic input of settings for the internet.
My TV has a HUMAX freesat HD box and the ethernet goes into that. When I search HUMAX forums they said the router was the problem (what do I know?).
I have tried setting the IP address etc by hand on the TV settings but still no joy. BBC iplayer still says TV is not connected to internet even though it is.
05-02-2012 10:51 AM
so confused
05-02-2012 10:52 AM
Has the Humax box got the latest firmware version (you'll find that on the menus) and exactly what model is it.
05-02-2012 10:55 AM
HUMAX FOXSAT HD
05-02-2012 11:07 AM
It's best to use the DHCP setting.
05-02-2012 11:08 AM
I had to upgrade mine when I got it before iPlayer worked.
05-02-2012 11:15 AM
05-02-2012 11:18 AM
05-02-2012 11:22 AM
Quote from: Strat I have a Foxsat-HDR and the software version is HPRSFCI 1.00.17
As is mine; that also works on iPlayer.
(2 systems in different rooms, 1 dish with quad LNB)
05-02-2012 11:23 AM
Quote from: suffolkcindy I didnt use the DHCP setting before
That WILL be your problem.
But surely it's the default anyway.
Doesn't say much about the help on the Humax forums though............
05-02-2012 11:30 AM
Checked software for humax box and it is HZPTSF 1.100.28 which others say works fine for them
Ethernet ID is 00-03-78-B6-C7-A1 if that means anything
Am really out of ideas now
05-02-2012 11:33 AM
this is why I went via manual and put in the IP address to start with
Have now tried manual and DHCP but of course with no recognistion of my router it cannot do it automatically...
