cant access the router
Wimpywoo
Hi, I can't access the router even though I have reset it, anyone got any suggestions please? Undecided
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: cant access the router
What router are you using?
Chris Pettitt
Cloud Environments Engineer
Wimpywoo
Technocolour on tg5829. I wonder what it could be  Undecided ? Thank you for your reply.
Fixes: 162
What error are you seeing when you try to access it?
 Chris Parr
 Plusnet Staff
Wimpywoo
I'm not seeing error , I'm unable to sign in , I managed to sign in once and clicked on a device to remove it from the router (my old iPhone because I've purchased another one!) And I was unable to remove the old iPhone and I was signed out! And not no matter what I do I can't sign in , nothing happens ? Thank you for your reply .
Adie:quote
Fixes: 21
Um, were you using your old iPhone to delete the device (itself)? Are you using the default TG582n password or did you change it to a different one?
edit: spelling typo.
Wimpywoo
Um, were you using your old iPhone to delete the device (itself)? Are you using the default TG582n password are did you change it to a different one?
hi no I was using this one HTC , I have sold the old one. I have tried everything you can think of. Thanks
[Moderator's note by Adie (dvorak):  Full quote of preceding post removed, as per Forum Rule]
dick:green Quote fixed.
Fixes: 162
As a last resort you could factory reset the router, but this will remove any settings you've added to it.
 Chris Parr
 Plusnet Staff
Wimpywoo
thank you for your reply , I have managed to fix it now thank you.
[Moderator's note by Dick (Strat):  Full quotes of preceding post removed, as per Forum Rule]
