cant access my home network from the internet
AlanLane1
Ever since getting a static IP my home network in inaccessible form the internet
A tracert gets as far as 84.93.253.144 and then stops
This looks like its in the plus network as the previous ip's are plusnet urls.
I have tried calling support and just get cut off because they are always too busy.
This connection is useless to me if i cant access it!
7 REPLIES 7
Mook
Seasoned Champion
Fixes: 9
Re: cant access my home network from the internet
What device(s) do you have connected to your Home network that you want to access?
Nothing on your LAN should be accessible from outside the network unless you have configured it yourself.
Fixes: 393
Unless there's something on your home network to accept the access , and you have suitable port forwarding on the router then you won't be able to access it.
Assuming you have the standard PlusNet Hub One router, then by default it won't respond to a ping on the WAN , hence the tracert failing.
AlanLane1
I have tried a router and a raspberry Pi
Both connected prior to asking for a static IP
AlanLane1
C:\WINDOWS\System32>tracert 80.229.19.249
Tracing route to alanlane.plus.com [80.229.19.249]
over a maximum of 30 hops:
1 11 ms 11 ms 10 ms 100.100.42.31
2 11 ms 10 ms 11 ms 100.100.42.252
3 11 ms 11 ms 11 ms 83.231.204.165
4 11 ms 11 ms 11 ms 212.119.4.141
5 12 ms 11 ms 11 ms 166-49-209-133.gia.bt.net [166.49.209.133]
6 22 ms 12 ms 12 ms core1-hu0-0-0-0.colindale.ukcore.bt.net [195.99.127.
7 163 ms 11 ms 269 ms be10.pcn-ir01.plusnet.bt.net [195.99.125.133]
8 22 ms 12 ms 13 ms gi4-0-22.pth-gw1.plus.net [195.166.129.209]
9 13 ms 12 ms 82 ms 84.93.253.114
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
AlanLane1
Im Guessing someone at Plus saw this post and fixed the routing.
Magically its working now Smiley
Fixes: 393
That's exactly what you would expect if the router doesn't respond to a ping from the WAN.
RealAleMadrid
Aspiring Hero
Fixes: 59
@AlanLane1  I don't know what fixed it but I'm 100% certain that Plusnet had nothing to do with it. They are hardly visiting the forum these days and the chances that they spotted your post and fixed things around 15 minutes later would be similar to winning the lottery jackpot.😀
