cannot enable static ip address
fatherjack666
Hi
Service went live 3rd October all good, I paid the £5.00 to get a static ip however I cannot enable it, I have clicked on enable static ip and restarted router but it still says your usubg dynamic ip, can someone please help me with this
5 REPLIES 5
willcutforth
Fixes: 113
Re: cannot enable static ip address
@fatherjack666 it should now be fixed for you! Sorry about that!
 Will Cutforth
corringham
Seasoned Champion
Fixes: 23
I is worth noting that the Plusnet static address is still allocated dynamically - it is just that it will always allocate the same address (in a different address range to the randomly allocated dynamic addresses).
This sometimes causes confusion.
fatherjack666
Thank you for sorting this so quick, I presume that it will 24hrs to populate as when I run whats my ip check it still thinks its 146. etc
willcutforth
Fixes: 113
@fatherjack666  If you just give the router a reboot it will be active immediately.
 Will Cutforth
RichardB
Seasoned Champion
Fixes: 40
Hi @fatherjack666
You need to drop the PPPoE login to Plusnet &  reconnect, or turn the router off and on again, to pick up the static IP address.
Regards
Richard
