can't connect tablet to wifi
brokengreen
Hi, I can't connect my android tablet to my router via wifi, the tablet asks for password which is I presume is as the one I use for my my pc, but will not connect after entering it.
My router is a Technicolor TG582n.
Many thanks.
12 REPLIES 12
zubel
Re: can't connect tablet to wifi
Hi brokengreen,
The password for the Wifi is printed on a label affixed to the bottom of the router, and is case sensitive, so ensure that you are using uppercase where relevant.  You should be able to tick 'view password' to double-check the letters/digits as they are entered on the tablet.
brokengreen
Hi, Barry Zubel, have done that a few dozen times by now with no result I have only just got the tablet so its all a bit new to me.
adamwalker
Fixes: 221
Assuming the PC is still able to connect with the same password I'd give the tablet a reboot. Failing that setting the router back to factory default (by holding a pen/pencil etc in the recessed button for 10 seconds) should set the password on the router back to defaults and should then precisely match the one on the sticker.
 Adam Walker
NedLudd
Have you initiated the 'Search for wireless devices' on the router?
The router also has to 'give permission' for the device to connect.
Geoff,
York.
brokengreen
Still no luck,i've tried all the suggestions with no success. Any futher advice would be most welcome.
brokengreen
Hi Nedludd, how do I do that?
Strat
Fixes: 565
Which WiFi channel are you using?
brokengreen
Sorry Strat i've no idea, i'm new to all of this
Strat
Fixes: 565
The reason I ask is because some devices won't connect to a channel above 11.
The router default is probably lower though.
Try installing WiFi Analyzer on your tablet and see what it finds.
brokengreen
Cant download the above ,tells me to enter google play ,tried that no luck.
ReedRichards
Seasoned Pro
Fixes: 25
Inssider http://www.metageek.net/products/inssider/ run on a regular PC would do the same job.
NedLudd
Quote from: brokengreen
From the router go :-
Home Network
Wireless
Pick a task
Whilst that is running make sure your tablet is trying to access the internet!
Simples.
Geoff,
York.
