can't connect no ethernet connection
FIXED- Subscribe to RSS Feed
- can't connect no ethernet connection
- « Previous
- 1
- 2
- Next »
Re: can't connect no ethernet connection
01-03-2024 4:39 PM - edited 01-03-2024 4:40 PM
This is a ADSL modem/router only
What is the Internet LED (third from left) doing?
On - Internet connection is available.
Flash - There is data being transmitted or received via the Internet.
Off - No successful Internet connection is available
Edit: If the LAN lights are flashing, this will be normal if a device is connected to one
01-03-2024 5:19 PM
When opening email site get a bunch of info, server error, network responder error. Had this problem loosing Internet a while. Try after 10 minutes then it connects only to drop again but it's stopped completely now. You see the diagnostics I ran ubove? Four ATM OAM Fails.
Oh I can do the "desktop site" now but there still nothing to click to attach. Thanks
01-03-2024 5:24 PM
On the desktop site 'reply' window, do you not see this:
Click the 'mountain' icon between the smiley and the camera, and follow the prompts.
01-03-2024 5:33 PM
Lan rapid constant flashing but no traffic, errors 'no ethernet'. Computer is still connected and I can log on to the modem.
What you mean adsl/router only? Adsl 2+ I posted earlier.
Thanks for help
01-03-2024 5:38 PM
@Dan_the_Van 's comment was to point out that you have an ADSL rather than FTTC connection, but I'll leave it to him to diagnose your problem - I'm out for most the rest of the day.
01-03-2024 5:46 PM
I suggest you check the broadband connections parameters are correct
01-03-2024 5:47 PM
01-03-2024 5:50 PM
04-03-2024 11:08 AM
Openreach engineer has been and the problem was in the street box. He fixed it and I now have the internet working again. Had a look at the modems diagnostics and it is still showing the 'Fails' (see image).
Anyone know why this is? Thanks
04-03-2024 11:29 AM
If the internet is working I would not worry about those fail messages, it could just be the ADSL terminal equipment does not support OAM cell test
Dan
04-03-2024 11:42 AM
Thanks for the reply. Engineer fixed the problem thank goodness. Appreciate everyones help. Will now mark this issue solved.
- « Previous
- 1
- 2
- Next »
