can't connect no ethernet connection
Fenster
Sorry if wrong place. Internet dropping and now stopped completely. Run diagnostics, how can i upload picture please?. On my phone Internet now to post this.
Tags (2)
25 REPLIES 25
Fixes: 334
Re: can't connect no ethernet connection
@Fenster On your phone, select the 'desktop' site, and you will then get the ability.
Fenster
That's on my mob phone or this forum? Can't see anything to click on forum or in phone settings. I'm old sorry.
Fixes: 334
What phone have you got? It is in the phone settings.
Fenster
Samsung galaxy s20 fe
Fixes: 334
Easier than me trying to explain - note you will need this site open when you do this:
https://support.google.com/chrome/answer/13514529?hl=en-GB
Fenster
Yes looked and not there. I'm going to have to phone plusnet support. Thanks all
ClaudiaG23
Fixes: 25
@Fenster  No need to call, I'm here. I'm just going to run some tests on your line. I'll get back to you within 10 minutes or so.
 Claudia Garner
ClaudiaG23
Fixes: 25
@Fenster I can see you've got no connection. What router is it that you're using please?
 Claudia Garner
Fenster
Oh thanks very much. Got this result sounds useful:
Testing ATM OAM SEG FAIL
END TO END FAIL
F4 segment FAIL
F4 END to end FAIL
Hope this helps
Fenster
TP-Link 300mbps wireless N adsl2+ (td W8961N) .modem router. Not a plusnet one.
I had my modem awithed off when you first posted, switched back on now sorry may have mudded the result of your testing. The padlock light on it is off for some reason.
Fenster
Hello, anybody there? Claudia?
Fixes: 334
@Fenster Do you still have a landline phone? What lights are on your router and what colour?
Fenster
Yes landlines phone working.
Lights on modem: power green, wireless green, adsl green, "padlock" light off, LAN Flashing green.
There are three LAN sockets back of modem all have same issue flashing.
Fixes: 334
That kind of sounds like you have everything working OK - what happens if you try to reach a site on any connected equipment?
