can new cables affect my router?
- can new cables affect my router?
23-11-2011 10:09 AM
Re: can new cables affect my router?
23-11-2011 10:16 AM
There could be a number of reasons, and the wireless channel you're connected to could be getting interference. You could use something like inSSIDer which can help you identify the clearest channel to use, this may help.
Jojo
23-11-2011 10:52 AM
Could it be that he's wired the Sky Box directly into the master socket so that there is no ADSL filter in the circiut ? that will really affect your speeds. The Sky Box phone connection MUST be routed through an ADSL filter.
23-11-2011 11:05 AM
23-11-2011 12:02 PM
I would have thought that's pretty well screened although I guess it does carry power for the LNB.
Quote The signals fed from the LNB, down the cable to the digibox, lie between 950-2150 MHz. Cellphones can use 1800 MHz and their signals could get into the system or the coaxial cable.
23-11-2011 12:10 PM
I'm sure Sky would use the best quality downlink cable from the LNB
24-11-2011 4:30 PM
Quote from: MisterW Ah, so you're thinking its the downlink cable from the LNB then Jojo ?
I was just thinking of the most obvious changes.
Jojo
