can my speed get any better
- can my speed get any better
05-11-2011 7:14 PM
Port Status TxPkts RxPkts Collisions TxB/s RxB/s Up Time
WAN PPPoA 6679403 6831500 0 5230 1542 20:27:46
LAN 10M/100M 6364719 6354844 0 52562 6582 20:31:31
WLAN 11M/54M 493687 343314 0 8460 592 20:31:21
ADSL Link Downstream Upstream
Connection Speed 3168 kbps 448 kbps
Line Attenuation 48 db 15.5 db
Noise Margin 15 db 25 db
can anyone at plusnet help me to improve my internet speed gaming is getting realy bad also team speek keeps droping all the time i am now using my old netgear dg834g-v3 the thompson is just poo stats above
Message 1 of 5
(1,011 Views)
4 REPLIES 4
Re: can my speed get any better
05-11-2011 11:13 PM
Can you connect the router to the TEST socket if you have a newish BT/Openreach master socket and get the line stats from there.
The TEST socket is the one at the back on the right as you look at the image > [color=red]TEST socket.
The removable section in the foreground should have any of your phone extensions wired into it (if there are some). [/color]
Message 2 of 5
(498 Views)
06-11-2011 2:33 PM
i can connect the router to the TEST socket but then i cant use my main pc if you give me a time period to test it that would be good
Message 3 of 5
(498 Views)
06-11-2011 10:30 PM
If possible it would be best to connect the router to the test socket in day light hours as you should get a reasonable sync rate, you could connect the PC up to it any time that suits either straight away or later in the evening and get the stats.
If you remember the approximate time of day you got the stats you posted earlier then a similar/same time as that would also do, it's up to you whatever is the easiest for you.
Message 4 of 5
(498 Views)
07-11-2011 5:00 PM
i will setup on test socket tuesday and use my laptop with the router them post stats thanks for your help
Message 5 of 5
(498 Views)
