can my connection go any faster JOJO PLEASE HELP IF YOU CAN OR OTHER ADMIN
- can my connection go any faster JOJO PLEASE HELP...
Re: can my connection go any faster JOJO PLEASE HELP IF YOU CAN OR OTHER ADMIN
13-06-2011 5:24 PM
13-06-2011 6:34 PM
plugged into test socket as you said on the phone keeping setup the same as mentioned above so still with my phone and Sky attached
14-06-2011 9:59 AM
The line's been stable since about half six last night, so I presume that's when your hubby plugged it into the test socket? Let's see how it goes for the rest of the day.
Jojo
14-06-2011 10:16 AM
yes thats when it was plugged into the test socket, think the longest it has been stsbl was about 1day 5 hours a few days ago so fingers crossed it stays connected this time, if it does then what i guess my router isnt the problem then?.
14-06-2011 10:53 AM
Although router problems do occur, the vast majority of the time, instability is caused by poor internal wiring or set up. Only time will tell though. I'll check it later on and see how it's going.
Jojo
14-06-2011 11:07 AM
will update this thread if I notice a disconnection thank-you for your help
Michelle
EDIT current BT test i think connection rate and ip profile are higher than my first test on first page
FAQ
Test1 comprises of Best Effort Test: -provides background information.
Download Speed
3117 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 3117 Kbps
Additional Information:
Your DSL Connection Rate :4960 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 4000 Kbps
14-06-2011 3:04 PM
just disconnected nearly made it to 24 hours but not quite reconnected at a faster speed
Today 15:03 3904 kbps (488kB/s) 378 kbps (47.3kB/s)
will check back in a bit
michelle
14-06-2011 3:14 PM
Don't worry it was a reset from our side because your profile went up, so wasn't a drop as such.
Jojo
14-06-2011 4:22 PM
15-06-2011 8:16 AM
Had a disconnection at some time this morning about 7 ish was still on bed so not even using it then.
Michelle
15-06-2011 10:15 AM
15-06-2011 10:21 AM
going through it now and need to get another router to try
15-06-2011 12:01 PM
Quote from: mkc66 ok and then what will happen?
The faults team will check the connection from your house through the network and raise it to our suppliers if necessary.
Jojo
15-06-2011 1:25 PM
Got as far as the section where it says have you tried a different router and answered no then it said the reasons why to try another router and gave 2 options I tried another router or I havnt and I may be charged so I borrowed my mothers router also a voyager2110 and she changed to plusnet just after me and neither of us could connect to our broadband with the other routers so have sent hers back and at a loss at what to do I cannot afford Bt to charge me any suggestions I am still part way through the broadband trouble shooter and font like to click I havnt tried a different router
Thanks Jojo
15-06-2011 1:55 PM
The faults team can then start their extended tests and if a router fault is identified as the most likely cause they will probably offer to lend you one. I'm sure they wouldn't arrange an engineer visit without an alternative router being tried if they felt it was necessary.
