can i use bt home hub 5 on plusnet?
- can i use bt home hub 5 on plusnet?
26-09-2014 2:46 PM
Re: can i use bt home hub 5 on plusnet?
26-09-2014 2:47 PM
and yup you can.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
26-09-2014 2:48 PM
Yes both 5A & B work fine on plusnet
26-09-2014 2:59 PM
26-09-2014 3:54 PM
Other than that it works very well
Regards, David
26-09-2014 4:45 PM
26-09-2014 6:44 PM
When I swapped from the Huwai older style modem to the HH5 I got an increase of about 5Mb/s on my download connection rate!
26-09-2014 6:49 PM
26-09-2014 6:54 PM
Quote from: Kevin The multi rebooting per day seems to have stopped on the HH5. Mine only reboots every 6-10 days ...
My HH5 connected at a lower speed than my Juniper SRX110(rock solid, never rebooted) and started rebooting. Not sure why, it was running the latest firmware.
