can i use bt home hub 5 on plusnet?
- Re: can i use bt home hub 5 on plusnet?
26-09-2014 2:46 PM
Hi I'm thinking of switching to plusnet but I've seen the router isn't the best in the world can i use my home hub 5 on the network?
Message 1 of 9
(3,698 Views)
8 REPLIES 8
26-09-2014 2:47 PM
welcome to the forums
and yup you can.
and yup you can.
Message 2 of 9
(1,475 Views)
26-09-2014 2:48 PM
Hi
Yes both 5A & B work fine on plusnet
Message 3 of 9
(1,475 Views)
26-09-2014 2:59 PM
Excellent thanks
Message 4 of 9
(1,475 Views)
26-09-2014 3:54 PM
Just remember you will need to change your broadband username in the HH5 to the one plusnet supplies and enter the plusnet password.
Other than that it works very well
Regards, David
Regards, David
Message 5 of 9
(1,475 Views)
26-09-2014 4:45 PM
Beware of BT Home Hub 5 rebooting itself all the times because of BT badge on it. Rebooting could affect DLM on your line. U're better off with standard BT Openreach Modem and use BT Home Hub 5 as the router.
Message 6 of 9
(1,475 Views)
26-09-2014 6:44 PM
The multi rebooting per day seems to have stopped on the HH5. Mine only reboots every 6-10 days and hasn't had any effect on the DLM
When I swapped from the Huwai older style modem to the HH5 I got an increase of about 5Mb/s on my download connection rate!
Kevin.
Message 7 of 9
(1,475 Views)
26-09-2014 6:49 PM
Works as a modem for both ADSL and VDSL (Fibre) with plusnet. Mine has been great - solid connection.
Message 8 of 9
(1,475 Views)
26-09-2014 6:54 PM
Quote from: Kevin The multi rebooting per day seems to have stopped on the HH5. Mine only reboots every 6-10 days ...
My HH5 connected at a lower speed than my Juniper SRX110(rock solid, never rebooted) and started rebooting. Not sure why, it was running the latest firmware.
Message 9 of 9
(1,475 Views)
