can i use a home hub 3 on plusnet
tonyt2764
i have a home hub 3 lying about is it possible to configure it to use on pn broadband cheers tony
mikeshe
Re: can i use a home hub 3 on plusnet
I'm using a Home Hub 5 and it works great. As far as I know you can use a HH3 on PlusNet. There's a thread on here which explains how to set it up, try a search for Home Hub and you should find it.
DanHodby
The guide is here Smiley
