can anyone help me.
- can anyone help me.
can anyone help me.
12-11-2011 11:45 PM
Hello Im mike and im new to forums. anyways iv got a problem and im wondering if any people who has got the Techcolor TG582n can help me and test theirs, Today iv noticed that i cant change my Interface Type: from 802.11b/g/n right up to 802.11b under the "configure". can you help me
Message 1 of 9
(1,189 Views)
8 REPLIES 8
Re: can anyone help me.
13-11-2011 12:01 AM
Why would you want to select B only? its 11mbps?
having it set to the three, will allow it to select it, itself
Regards
Regards
Message 2 of 9
(623 Views)
13-11-2011 12:01 AM
What i mean is i can't select anything.
Message 3 of 9
(623 Views)
13-11-2011 12:18 AM
I dont understand why you'd want to be limiting it?
Regards
Regards
Message 4 of 9
(623 Views)
13-11-2011 12:23 AM
Im just wondering why i cant select any mode thats all. I know the 802.11b/g/n is the best option for performance.
Message 5 of 9
(623 Views)
13-11-2011 1:14 AM
perhaps to stop people tinkering with things that they shouldnt tinker with?
Or perhaps an omission in the firmware and it will be added in a subsequent release
Regards
Regards
Message 6 of 9
(623 Views)
13-11-2011 1:29 AM
Hi has anyone got the Thomson TG582n, if you have can you do a test for me like you can see my Interface type is missing so i cant select any mode from 802.11b/g/n to 802.11b if i want to change it, So if you have the same Router has me can you check yours and send me a message.
Thank you.
Thank you.
Message 7 of 9
(623 Views)
14-11-2011 2:21 PM
Hi mike360,
Yes, strangely enough I've just tested a 582 here and the option to change it is not on the configuration pages. I have flagged this up to our team who deal with the router manufacturers and they will pass this on - it usually means that they will fix it in the next firmware upgrade.
Jojo
Jojo
Message 8 of 9
(623 Views)
14-11-2011 2:47 PM
cheers jo
Message 9 of 9
(623 Views)
