can a admin please do me a request for interleaving.
matty2k13
Can a admin please do me a request for interleaving to be turned off on my line before the weekend so I dont have to wait till monday
Plusnet Alumni (retired) LinnPlusnet
Re: can a admin please do me a request for interleaving.
Hi matty2k13,
I've checked your line and interleaving is turned off. Are you experiencing any problems?
Fixes: 25
Why do you think interleaving is turned on?  If your router does not report FEC errors (which given Linn's response it should be the case) then interleaving is not turned on.
matty2k13
I posted a few weeks ago about lag I had. And someone said that interleaving is on
matty2k13
FEC Events (Down/Up):0 / 0
Thats after 2days so does that mean its off ?
matty2k13
Just gettin bad lag in all my online games on ps4
All ports are open and everythink but still bad lag
Plusnet Staff
Plusnet Staff
Fixes: 5
Yep - it's off.
What game are you playing and what's your ping looking like?
Chris Pettitt
Cloud Environments Engineer
matty2k13
Playing call of duty ghosts amd fifa 14. Ping is around 35ms
Plusnet Staff
Plusnet Staff
Fixes: 5
You shouldn't be seeing lag with 35ms ping  Crazy
Chris Pettitt
matty2k13
Well I am getting real bad lag. Its unplayable at times. I have opend ports tryed 3 routers new cables but still lagging. I need this sorted asap
Fixes: 10
Wired or wireless connection to the router?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
matty2k13
Wired mate
matty2k13
Could it be down to openreach trying to get my fiber cabinet up and running because it only started since they started pissin about with the fiber cabinet and the old cabinet
Plusnet Staff
Plusnet Staff
Fixes: 5
It could be.
Looking at your line though, it's completely clear. There's no Interleaving on. Your sync rate is 4544K which good for the line length.
Chris Pettitt
