calling the experts
- calling the experts
calling the experts
05-01-2009 8:18 PM
what sort of sync speen should I get with the followins stats
output Power Down: 19.5 dBm, Up: 12.0 dBm; line Attenuation Down: 48.0 dB, Up: 23.5 dB; snr Margin Down: 9.5 dB, Up: 8.0 dB)
thanks
thanks
Message 1 of 6
(1,165 Views)
5 REPLIES 5
Re: calling the experts
05-01-2009 8:36 PM
Hiya,
I used to get something in the region of 3.5Mbps sync speed with relatively similar figures, albeit my SNR was a little bit lower.
What sort of speeds are you seeing?
Message 2 of 6
(578 Views)
05-01-2009 8:40 PM
Hi James
Getting 4864 tonight which isn't bad.
However has been as low as 2000 this last few weeks.
Better than expected then
Message 3 of 6
(578 Views)
05-01-2009 8:41 PM
My stats are pretty close to what you are seeing..
ADSL Link Downstream Upstream
Connection Speed 6240 kbps 832 kbps
Line Attenuation 49.0 db 26.0 db
Noise Margin 5.1 db 9.0 db
Message 4 of 6
(578 Views)
05-01-2009 8:47 PM
You should get a good 4Mbps I would have though. My attn is 42dB, and SNR of 6dB, and I get a good 5000-5500 sync speed, giving me a throughput of 4.5Mbps.
Message 5 of 6
(578 Views)
05-01-2009 9:20 PM
Quote from: newmillscomp Getting 4864 tonight which isn't bad.
Hi again
Are you talking about a fluctuation in sync speed or the actually throughput? Your speeds seems reasonable (tonight) for the length of your line, but if you're seeing variations of that nature I'd be a little concerned.
Message 6 of 6
(578 Views)
