buying more Gigs
- buying more Gigs
buying more Gigs
12-09-2007 12:27 PM
how do you buy more gigs in the broadband your way deals?
Message 1 of 2
(770 Views)
1 REPLY 1
Re: buying more Gigs
12-09-2007 12:39 PM
Hi
In order to add more usage if you follow these steps:
1. login to portal
2. go to connection settings (on the left hand side)
3. there should be an option to control your broadband with additional options to add more usage and to upgrade the account, this is usually done immediately.
If you've gone over your included usage your additional usage is charged at £1 per Gb, if you are still within your inclusive downloads you are charged 75p per Gb. You can set the account up to have, for example, Option 2 with 10 Gb inclusive (8Gb as standard and an additional 2 at 75p each) giving you a monthly cost of £16.49.
Any problems just reply here and someone will assist further.
1. login to portal
Message 2 of 2
(249 Views)
