buffering
- buffering
buffering
16-11-2018 5:15 PM
I,m constantly having trouble streaming Netflix and sport, speed checks are always random, driving me mad.
Anyone else????
Re: buffering
16-11-2018 5:37 PM
Not here. Try several sites if running speed tests.
Re: buffering
16-11-2018 10:05 PM
Welcome to the forum.
Are you on standard broadband or fibre? Are you connecting via an Ethernet cable or wireless? Speed tests should use a direct Ethernet cable connection as this is the only way of checking the quality of your broadband connection as being supplied by Plusnet . If this is OK then you have a wireless problem, which requires a different approach.
