bt speedtester results
I have raised an issue with my speed and PN are looking into it on my behalf. I have just comlpeted the  bt speedtester. On the final page it states that i should contact my isp to discuss these results. My question is DO PN automatically get sent a copy of these results each time I complete the test.
Currently connected via master socket.
Regards,
Podman
Fixes: 172
Re: bt speedtester results
AFAIK you will need to update the ticket with the results of your speed test as PN don't get sent the results.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
will try again and update the ticket cheers.
podman
ramidoodle
Yes we can check the results using BT Wholesales diagnostic tools Smiley
Thanks for the advice.
Podman
