bt speed test thru the floor
I'm just back from holiday. i turned the router back on to get a fantastic sync rate but the a bt speed test to show the thru put shows 7680 Kbps
How long will it take to rise to a true speed. Can't post a screen dump and the netbook as W7 starter which dosn't have snip tool. text dump below:
FAQ
Test1 comprises of two tests
1. Best Effort Test:  -provides background information.
Download  Speed
281 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 281 Kbps
For your connection, the acceptable range of speeds is 2000-7150 Kbps.
Additional Information:
Your DSL Connection Rate :7680 Kbps(DOWN-STREAM), 445 Kbps(UP-STREAM)
IP Profile for your line is - 6775 Kbps
2. Upstream Test:  -provides background information.
Upload Speed
358 Kbps
0 Kbps 445 Kbps
>Upload speed achieved during the test was - 358 Kbps
Upstream Rate IP profile on your line is - 445 Kbps
Thinkbroadband is the same
Date 21/10/11 16:48:35
Speed Down 373.79 Kbps ( 0.4 Mbps )
Speed Up 371.81 Kbps ( 0.4 Mbps )
Re: bt speed test thru the floor
Hi Podman,
The BT profile's at 5000 on the delta report side and ours is set to 7000, are you still seeing the same slow speeds?
HI Matt,
just tried iplayer can't even get sd feed to work without major buffering.
will try bt speed test again in 10 mins or so once the hour has passed
Still no real improvement
Download  Speed
866 Kbps
0 Kbps 7150 Kbps
Download speedachieved during the test was - 866 Kbps
Upload Speed
310 Kbps
0 Kbps 445 Kbps
>Upload speed achieved during the test was - 310 Kbps
This test was not conclusive and further testing is required.This might be useful for your ISP to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
cheers matt it appears to have taken a couple of hrs and a few reboots but all appears well.
speedtester.net showing 6.23mb and pn now showing 7mb is speed estimate. was 5 when i initially checked before posting.
hopefully higher speeds will remain.
podman
