bt home hub v3
- bt home hub v3
bt home hub v3
11-07-2011 11:19 PM
will this work with my new plusnet connection?
Message 1 of 9
(1,808 Views)
8 REPLIES 8
Re: bt home hub v3
11-07-2011 11:23 PM
Yes. Several posters on here are using it.
Message 2 of 9
(715 Views)
Re: bt home hub v3
11-07-2011 11:25 PM
so is it just a case of switching from bt to plusnet without a config change?
Message 3 of 9
(715 Views)
Re: bt home hub v3
12-07-2011 1:45 AM
No. You'll have to enter your username@plusdsl.net - I think you can do this via the Advanced Settings.
Message 4 of 9
(715 Views)
Re: bt home hub v3
12-07-2011 10:17 AM
Is this the NEW bt hub? Are they still compatible. I know the v1/2's are but didn't know about the new V3 one.
Message 5 of 9
(715 Views)
Re: bt home hub v3
12-07-2011 10:52 AM
got it working wanted to use this instead of the thomson due to the wirless range and spec http://www.filesaveas.com/bthomehub3.html
Message 6 of 9
(715 Views)
Re: bt home hub v3
13-07-2011 4:14 PM
Forgot to mention that the bt v3 also is infinity capable
Message 7 of 9
(715 Views)
Re: bt home hub v3
20-07-2011 1:53 PM
Is anyone able to tell me how to configure the HH3 for plusnet?
There seems to be detailed info available for the HH2 but not for the new one (that I can find anyway!).
Any help would be greatly appreciated.
SIMON
SIMON
Message 8 of 9
(715 Views)
Re: bt home hub v3
20-07-2011 1:59 PM
Ah - might have answered my own question - you need to be disconnected in order for it to allow you to change the broadband username. (I'm still on BT until 27th but was forward planning!)
Message 9 of 9
(715 Views)
