bt home hub 3
mccoll2u
bt home hub 3
Its time for me to upgrade router as I have the Thomson one plusnet sent me a year ago nothing wrong its just white and doesnt fit my decor im picky that way lol.
I am looking at getting  the bt home hub 3 looks a nice bit of kit anyone got this and is it anytime ?
Fixes: 234
Re: bt home hub 3
Not sure that you can use it on PN, it's pretty locked down.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
Re: bt home hub 3
I've got one - it works fine.
mccoll2u
Re: bt home hub 3
Using it now its good just wish I was able to shut off bt fon and openzone
Re: bt home hub 3
You shouldn't have those activated as you aren't a BT Total Broadband user. Which model hub do you have?
mccoll2u
Re: bt home hub 3
Bt homehub 3 got it used from fleabay
Re: bt home hub 3
There should be a way to turn those off somewhere in the GUI, but as mine hadn't been used before I got it, I've no idea where.
Re: bt home hub 3
I've just spent a good hour or more on Google trying to find a way to disable this in the Home Hub 3 to no avail - the previous owner of your hub must have been opted in to BTfon and hadn't opted out before offering the hub for sale. Huh
bill888
Seasoned Pro
Fixes: 24
Re: bt home hub 3
fwiw, does a full factory reset of the home hub make any difference ?
Update:
This BT web page link refers to perhaps needing to reactivate BT FON after performing a factory reset.
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
ie. it perhaps suggests a factory reset of the router will remove BT FON/Openzone functionality.
Re: bt home hub 3
Couldn't hurt to try...
kdoug007
Re: bt home hub 3
hiya  i have  just  joined, plus  net  and  will be  going  LIVE  next  friday..
  i have  at the  moment  a BT  HUB  ROUTER  2.0  its  one  with the phone,,,
However  i  dont think i will use  it  as  im  getting  a  wireless  router  via  plus net,
and  anyway the  phone  wont  be  much  use!
Fixes: 68
Re: bt home hub 3
some customers have managed to operate a home hub for our service but you may find it easier to switch to the router we're sending you.
 Adam Walker
Fixes: 52
Re: bt home hub 3
It might be, if you're up for a challenge...
Read here http://www.josephn.net/bt_home_hub_and_voip about configuring the Home Hub for other voip providers.
If you decide its feasible then you can activate your PlusNet Broadband phone, see here http://www.plus.net/support/phone/broadband_phone/index.shtml
