bt home hub 3 type b can I use it adsl
- bt home hub 3 type b can I use it adsl
09-04-2013 12:26 AM
Hi just wondering if I can replace the supplied router with this
Message 1 of 7
(1,443 Views)
6 REPLIES 6
Re: bt home hub 3 type b can I use it adsl
09-04-2013 12:37 AM
Yup. You just need to enter your Plusnet username/password.
Message 2 of 7
(554 Views)
09-04-2013 1:20 AM
Certainly can, works a treat.
Message 3 of 7
(554 Views)
09-04-2013 9:05 AM
Find my steps here - http://community.plus.net/forum/index.php/topic,113727.msg978370.html#msg978370
This was for Bwimog if he wanted to use a hub 3.
But those are the steps both same steps for either ADSL or Fibre.
Hope this helps!!
Hope this helps!!
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 4 of 7
(554 Views)
08-06-2014 1:15 PM
brilliant, now my broadband has a great connection, why would plusnet stick us with crappy routers, they obviously need to upgrade their routers, i was almost canceling my account with plusnet over this problem with the connection to their router, it was doing my head in...
Message 5 of 7
(554 Views)
13-06-2014 11:56 AM
nope i thought i sorted it but no... plusnet sucks ! ! !
Message 6 of 7
(554 Views)
13-06-2014 10:27 PM
Cheap service... it's what you get, sorry you don't like it.
Message 7 of 7
(554 Views)
