bt home hub 3 type b can I use it adsl
crobertbailey
Hi just wondering if I can replace the supplied router with this
Re: bt home hub 3 type b can I use it adsl
Yup. You just need to enter your Plusnet username/password.
apjashley1
Certainly can, works a treat.
NorthEasterner
Find my steps here - http://community.plus.net/forum/index.php/topic,113727.msg978370.html#msg978370
This was for Bwimog if he wanted to use a hub 3.
But those are the steps both same steps for either ADSL or Fibre.
Hope this helps!!
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
lisatoye
brilliant, now my broadband has a great connection,  why would plusnet stick us with crappy routers, they obviously need to upgrade their routers, i was almost canceling my account with plusnet over this problem with the connection to their router, it was doing my head in...
lisatoye
nope i thought i sorted it but no... plusnet sucks ! ! !
NorthEasterner
Cheap service... it's what you get, sorry you don't like it.
