bt 2700 hgv
noddy8
bt 2700 hgv
Hi I'll be moving from BT shortly and I'm on a long line Attenuation: 57.2 dB I've found the best router so far is the old two wire 2700hgv , are there any problems using this with Plusnet or any tips . Cheers
ian007jen
Re: bt 2700 hgv
Use the page=hurl13 method mentioned on this page http://bt2700hgv.tripod.com/063.htm to enter your plusnet username and password.
Ian
noddy8
Re: bt 2700 hgv
Many thanks I'll give it a go  Smiley
Fixes: 162
Re: bt 2700 hgv
Should work fine, I had one of these several years ago and there was no issue.
 Chris Parr
 Plusnet Staff
noddy8
Re: bt 2700 hgv
HI broad band up and running now  Smiley tried the 2700 first and just a red internet light  Cry got the plusnet router working , would it be worth trying the 2700 again now the connection has been made ? cheers
ian007jen
Re: bt 2700 hgv
Give it a go..
Plug in the 2700....the internet light will be red
Plug computer in via ethernet (or maybe connect via wireless)....goto http://home/xslt?PAGE=HURL13 or http://192.168.1.254/xslt?PAGE=HURL13
Type in your adsl username and password. The System Admin password is the S/N serial number found on the label attached to the hub.
When you see 'Re-attempting' message appear on the screen, this confirms the hub has successfully saved your PPP username and password. Restart the hub, and when both the Broadband and Internet LEDs turn Green, you are successfully connected to the internet.
More info http://bt2700hgv.tripod.com/063.htm#Setting up the 2700HGV (BT firmware v6.x)
Ian
noddy8
Re: bt 2700 hgv
Hooray  Smiley the old 2700 is back in use !!!! although at the side of other routers I've used the little Plusnet one was doing pretty good I was impressed but not quite as good as the 2 wire . Thanks for the help
