broardband speed
Teds31
broardband speed
I have just been on chat for about 2hrs 4agents and seems I got nowhere ,my seed tests show ping 65ms   speed down1.15 mbps     up 0.8 mbps. I was getting ping 15ms down 6.0mbps  up 0.8mbps,  only a few weeks since. Plus net just dont care or they are too busy to get in touch. They ask you to jump though all the hoops and then cant give you a few mins of their time .
MrSilver
Fixes: 9
Re: broardband speed
Was this meant for the feedback section for Plusnet ?
Teds31
dont really know what feedback section is, it seemed to get a reaction from pn thats all i intended
MrSilver
Fixes: 9
It's the section on the forums called feedback 😀
https://community.plus.net/t5/Plusnet-Feedback/bd-p/Plusnet
If it's had the desired impact and your problems are resolved then good!
Teds31
I have been told that my problem is being dealt with that was on Friday how long do I wait for information
Teds31
plusnet on the job , hope its not too long now.
Fixes: 162
Upstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
25.8 6 0 0 761769 1011
Downstream Link Info
43.6 6.1 13 N/A 10376234 1272
Your line is connecting through at a very very low rate compared to what we'd expect, based on the loop loss and the estimates this should be much higher. Can you confirm the router is in the master socket with NO extension leads in use please.
 Chris Parr
 Plusnet Staff
Teds31
I can confirm that the router is connected directly into the master socket with a new filter and just the telephone ,no other equipment .I have removed the face plate.
