broadband
lornaparsons
broadband
Since i have changed from my last supplier the broadband ,netflix etc has been the worst i have ever had.In the evening i cant do anything ,pages take ages to load or dont load at all ,films on netflix take twice as long to watch because they keep stopping ,i want to know what you are going to do about it.I dont really care what MB you say i get down my phone line i am not getting the service that i pay for.This never happened with my previous supplier and it is the same phone line so whats changed ,do you slow it down to make more money surely the speeds should be the same as it is THE SAME PHONE LINE.if you dont sort it out i will change supplier contract or not ,you are not supplying the service that i should be getting
15 REPLIES 15
adamwalker
Fixes: 221
Re: broadband
I've just been testing your line but can't see any obvious causes for the problem.
Are the devices you've been seeing this problem with connected over WiFi?
 Adam Walker
lornaparsons
Re: broadband
yes laptop and tv ,i never had any problems before
adamwalker
Fixes: 221
Re: broadband
Cheers for getting back to us, it would be a good idea to try following the checks here next: https://goo.gl/OwfjxM
Please keep us posted so we can keep following things up with you.
 Adam Walker
lornaparsons
Re: broadband
But the thing is i have had broadband for a lot of years and been set up the same way and never had any problems until i changed to plusnet
It happens between 7 - 11 pm ,tried to watch a program on netflix last night and it buffers so many times it is unwatchable ,do you think this is acceptable
JayG
Fixes: 6
Re: broadband
Your set up might not have changed, but the usage of other Wifi channels in your area might well have without you being aware of it.
Worth installing an app like 'Wifi analyzer' to discover exactly what is happening and whether you would fare better changing channel.
If you don't want to use an app, at least try a channel you're not already on - 1, 6 and 11 usually work best.
Cagney1994
Re: broadband
@JayG - Or use a wired connection to eliminate any WIFI issues.
lornaparsons
Re: broadband
how do you change the channel ,thanks
JayG
Fixes: 6
Re: broadband
You need to log into your router first - if it's a PlusNet router all you should need to know is in this link (channel setting/changing is reached via the 'Wi-Fi Network' settings):
https://www.plus.net/help/broadband/router-user-guides/
Fixes: 1,600
Re: broadband
How'd you get on with this lornaparsons?
lornaparsons
Re: broadband
To be honest i havent ,i try and log on to the router and you get pages and pages ,telling you to do different things ,then i realised i have been at this address for over 10 years with broadband and have never encounted a problem until i joined you ,why is this.
Why do i have to spend a long time trying to sort out the problem which i pay you for
I cant watch anything in the evening ,buffers so many times ,i cant bid on ebay because pages dont load ,takes so long ,why should i have to put up with this
I am know ready to jump ship and go with  provider who dosent supply such a [-Censored-] service
Fixes: 1,600
Re: broadband
Wireless signal is affected by numerous environmental factors, which are out of our control.
We're responsible for your connection from the exchange to your property.
This guide explains how to change the wireless channel which should help you.
lornaparsons
Re: broadband
Wow you really like to pass the buck as usual for a company ,DID you not hear me,BEFORE i joined your [-Censored-] service i had NO PROBLEM with anything ARE you getting that ,so where does the wifi come from, your box ,so your box is some chinese rubbish that cant do the job ARE YOU LISTENING 10 YEARS WITH NO THATS NO PROBLEM UNTIL I JOINED YOU I did try the other channels SAME old [-Censored-] if not worse
JayG
Fixes: 6
Re: broadband
You haven't stated whether you have tried using a wired connection to see if the problem persists, so the possibility remains you have a Wi-Fi reception problem which isn't necessarily PlusNet's fault.
Not much point you continuing to post in your thread if you choose to keep ranting rather than co-operating with those trying to help you.
Cagney1994
Re: broadband
@lornaparsons - Try a wired connection. If no joy, then you may need to change filter(s) or router. PN may send you another one.
Oh, and as it's been mentioned, ranting and raving won't get you anywhere.
