broadband
- broadband
broadband
28-05-2014 3:21 PM
hi guys,lost sync twice earlier on between 11:00 and 12:00 and 12:00 and 13:00 current line speed was 12.9mb and now is 2.8mb any ideas.....
Message 1 of 5
(687 Views)
4 REPLIES 4
Re: broadband
28-05-2014 3:55 PM
Hi sully72,
Your line synced at a very low rate on earlier but has now jumped back up, so I've changed your profile to 14.1Mb/s. I can't see anything that caused the decrease on your line.
Message 2 of 5
(453 Views)
Re: broadband
28-05-2014 4:22 PM
hi chris,thanks for that but still only getting 2.6mb on speed testers......
Message 3 of 5
(453 Views)
Re: broadband
28-05-2014 4:30 PM
If you could login to your router and click disconnect then connect that should do the trick.
Message 4 of 5
(453 Views)
Re: broadband
28-05-2014 4:45 PM
all sorted now thanks chris.....
Message 5 of 5
(453 Views)
