broadband still not working properly
- broadband still not working properly
Re: broadband still not working properly
12-01-2011 9:53 AM
12-01-2011 11:54 AM
Connection information
Line state Connected
Connection time 0 days, 18:37:56
Downstream 2,912 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Modulation ITU-T G.992.1
Latency type Fast
Noise margin (Down/Up) 14.8 dB / 22.0 dB
Line attenuation (Down/Up) 54.0 dB / 31.5 dB
Output power (Down/Up) 17.8 dBm / 11.8 dBm
Loss of Framing (Local) 11
Loss of Signal (Local) 1
Loss of Power (Local) 0
FEC Errors (Down/Up) 0 / 0
CRC Errors (Down/Up) 238 / 2147480000
HEC Errors (Down/Up) nil / 0
Error Seconds (Local) 163
Is there anything i can do get better stats
12-01-2011 12:20 PM
That is an insane amount of errors..... INSANE!!!
I assume in your last post that was the BT router?
Notice the difference from your last post: CRC Errors (Up/Down): 0 / 547
Any CRC is bad
I have had 0/3 in the last 7 weeks.
If you have that many CRC errors in the test socket you need a broadband engineer out to your house like.... yesterday
12-01-2011 12:33 PM
12-01-2011 12:50 PM
http://en.wikipedia.org/wiki/Cyclic_redundancy_check if you want to understand it in detail.
12-01-2011 1:15 PM
12-01-2011 3:48 PM
If multiple packets are sent out, then each response will take a different amount of time to get back, so there are multiple ping times.
Jitter is an indication of how variable those various ping times are. Low jitter means that all the ping times are similar, while a high jitter indicates a large variation in the times.
High Jitter indicates delays somewhere in the path between you and the destination. It might be a delay caused by retries on your DSL line, but could be a queue in any of the routers inbetween A and B. It is hard to tell, unless the thing being pinged is immediately on the other side of your DSL connection.
BTW - I'm not convinced that the CRC value of 2147480000 is a real reading.
It is suspiciously close to the value for 2^31 (2147483648) to be a coincidence - and is more likely a bad output of a negative number, or somesuch.
I'd trust it more if I'd seen errors gradually accumulating up to that value, rather than it suddenly appearing.
It is also untrue that *any* CRC is a bad thing. When you turn interleaving off (to reduce the ping time) you are also removing the error correction (so FEC counts become zero).
This does indeed mean that any errors that could have been corrected (using FEC) are now hard errors (counted within CRC) that must be retried.
But the positive aspect of turning interleaving off is that you gain the bandwidth used by the FEC mechanism (for example, 7616 becomes 8128 kbps, a gain of 6%). Getting CRC counts as high as 6% would then only put you back to square one. There are 59 ADSL frames/sec, so around 3 CRC's/sec is about break-even.
Certainly emzx23x's CRC count of 238 in 18 hours (downstream) is fine - around 13 CRC's/hour, or about 0.01%. Similar to my own line.
Using FTTC since 2011. Currently on 80/20 Unlimited Fibre Extra.
13-01-2011 10:23 AM
more recent statsADSL line status
Connection time 1 day, 17:08:14
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Latency type Fast
Noise margin (Down/Up) 14.3 dB / 22.0 dB
CRC Errors (Down/Up) 476 / 2147480000
Error Seconds (Local) 310
13-01-2011 12:35 PM
If the line keeps looking stable, then you might be able to get some speed improvements: However, "Stability first, speed second" is BT's motto here.
Have BT done anything to your line yet? Your last mention of this was that you expected a call back within 48hrs.
Right now your noise margin looks to be targetted around 15dB, which will have been set that high by BT because of previous errors.
It isn't clear if your current stability is because the noise margin is that high, or because BT have fixed your line, or (perhaps) things have been fixed because of the new router.
Oh - and were those figures with the router plugged into the test socket?
13-01-2011 4:01 PM
and to my knowledge bt havn't done anything to my line yet. been waiting for my ip profile to update for 2 days lol
ADSL line status
Connection time 1 day, 22:36:17
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Latency type Fast
Noise margin (Down/Up) 14.6 dB / 22.0 dB
CRC Errors (Down/Up) 521 / 2147480000
Error Seconds (Local) 347
13-01-2011 4:15 PM
we sent you a router as part of the fault finding process, it would really help us find out what is going on if you were to test it.
Jojo
13-01-2011 4:26 PM
13-01-2011 4:38 PM
let me know when it's on and I'll let the faults guy know.
Jojo
13-01-2011 6:43 PM
now speed has decreased because of disconnections any chance some one can reset my line to increase speed quicker?
Connection time 0 days, 1:15:19
Downstream 2,752 Kbps
Upstream 448 Kbps
ADSL settings
VPI/VCI 0/38
Type PPPoA
Latency type Fast
Noise margin (Down/Up) 16.0 dB / 22.0 dB
Output power (Down/Up) 17.7 dBm / 11.9 dBm
Loss of Framing (Local) 0
Loss of Signal (Local) 0
CRC Errors (Down/Up) 28 / 2147480000
Error Seconds (Local) 21
13-01-2011 6:46 PM
